Page 337 of 389 FirstFirst ... 237287327333334335336337338339340341347387 ... LastLast
Results 6,721 to 6,740 of 7777
    Apr 2009
    #6721
    Quote Originally Posted by ebirest View Post
    Everest trend user here
    Question mga sir
    Meron ba tpms mga titanium?
    Pwede ba ko magkabit sa trend ko and use forscan para maview sa dashboard?
    Saan kaya nakakabili nung sensor?
    Thank you
    Titanium Premium lang sir may tpms and you can't even view the exact values. Bili ka na lang nung tpms packages online o sa mga auto accessories shop kung gusto mo ng tpms. Plug and play lang mga yun so no need for forscan.
    Sent from my GT-I9505 using Tapatalk
    Aug 2007
    #6722
    Quote Originally Posted by Janemar View Post
    What year and model mo sir?
    2018 titanium plus sir
    Jan 2016
    #6723
    Quote Originally Posted by ferrarifan View Post
    thank you sir.. so hindi din accurate yung nasa titanium? may nakita kasi ako nagbebenta ng ford tpms oem..
    Apr 2009
    #6724
    Accurate naman sya. Kaya lang the dash wasn't designed to show the exact values, for now at least.
    May 2007
    #6725
    maugong primera nyo? ang ugong ng primera ko ngayun ko lang napansin. hindi ko tuloy alam kung normal ba yun o hindi. pag higher gear tahimik naman makina. if not 1st gear, 2nd gear yun
    Quote Originally Posted by eido View Post
    odometer reading? how old is the car? 3.2 variant?
    May 2007
    #6727
    less 3k odo hehe. trend 2.2 model. 2017 lang nabili. balak ko na nga pumunta ng ford at mag test drive unit kunwari balak ko kumula kotse para malaman kung may ugong din test car
    Jun 2009
    #6728
    less 3k odo hehe. trend 2.2 model. balak ko na nga pumunta ng ford at mag test drive unit kunwari balak ko kumula kotse para malaman kung may ugong din test car
    AN ACT STRENGTHENING CONSUMER PROTECTION IN THE PURCHASE OF BRAND NEW MOTOR VEHICLES
    Republic Act No. 1642 | Official Gazette of the Republic of the Philippines
    Sent from my BLA-L29 using Tsikot Forums mobile app
    go for it! let us know how the test unit sounds compared to your everest..
    May 2007
    #6730
    Quote Originally Posted by antoine_hans View Post
    Republic Act No. 1�642 | Official Gazette of the Republic of the Philippines
    meron ka na kilala na naka gamit nyan?
    Aug 2007
    #6731
    Ask ko lang waterproof ba yun base ng antenna? kahit wala nakakabit na antenna?Tinanggal ko kasi yun antenna sobrang haba masyado kasi mababa yun lower basement namin kaya feeling ko maski sharksfin tatama.
    Oct 2015
    #6732
    Kailan siya maugong sir? Pag bago andar from overnight park? Happened to me before pag sobra tagal naka idling after magdamag sa garahe. Rough takbo ng engine, maugong pero nawawala din shortly after. Kaya ginagawa ko ngayon is kung matagal idle before umandar, press ko gas pedal slightly every now and then till umandar na. So far di na umugong ulit sa low gears.
    IIRC, may napost na before (not sure saan) na prolonged idling or warm up is not good sa makina.
    HTH
    Jul 2016
    #6733
    Quote Originally Posted by haihuat View Post
    Meron dapat yan.
    Naka admin na key ba gamit mo?
    Yes sir. Kahit tangal oks lang
    Jul 2016
    #6734
    Quote Originally Posted by Head-On View Post
    HTH
    Ung ugong galing sa engagement ng viscotronic clutch fan(aka. Electro-viscous clutch fan, google na lang.) Ung ugong is ung lakas ng buga ng hangin.
    Nag fully ON sya if;
    1. A/C is switched on and refrigerent High side pressure is above X-PSI(di ko kabisado, around 150psi ata.)
    2. Coolant temp at 100 deg. C and above.
    Oct 2015
    #6735
    Might ba number 1, forgot to mention pinapatay ko compressor first few times nangyari then nawala ugong.
    Thanks once again sir janemar, galing mo talaga.
    Aug 2007
    #6736
    Meron dapat yan.
    Autolock
    Autounlock
    Mislock
    Remote Unlock
    Switch Inhibit
    Yan lang yun nasa settings ng lock walang auto relock need kaya ng forscan yun?
    Takot ko kasi baka nakaconektado sa radio yun base ng antenna at pagnabasa ng tubig either sa washing/cleaning or ulan Ma ground yun radio
    May 2007
    #6737
    yan din ba reason baket maugong yung sa akin? normal yan o hindi? ano kelangan ko ipa check kung hindi normal or ano kelangan ko check? i have elm
    HTH
    pag nag accelerate maugong yung sa akin.
    #6738
    an absolutely biased law favoring the auto companies. the only way it will work for you (consumer) is if you have a high ranking padrino in the dti.
    - 3 repeats of the same problem before you can report
    - total 5 attempts to repair before you can file for replacement/refund
    - 10% depreciation charged per year or fraction thereof to the consumer. that is even if the car is in the dealer for repairs for 1 year the law still charges depreciation to the consumer. so if it takes them 2 years to admit it is a lemon then you lose your 20% down payment.
    Oct 2015
    #6739
    Throughout the day yan sir or kapag first run in the morning or cold engine pa?
    May 2007
    #6740
    throughout the day. ang ginagawa ko para mawala tapik tapik sa gas habang low gear. pag isang apak na madiin kse ang ingay.
Ford Everest 2015
