not all mazdas are from japan. they have thailand and malaysian and american assembly plants.
nissan juke as per SA came from japan nung nag inquire kami
ero binili ko elm na working sa forscan
217 Bluetooth Version ELM327 ELM 327 FTDI chip with switch for F rd HS CAN and MS CAN car diagnostic cable free Shipping-in Electrical Testers & Test Leads from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
*eido,
Medyo natabunan na ata ung posts dati, may option ba paganahin ung perpendicular park assist thru FORScan? And working ba siya?
Not really. It doesn't help depressing it harder if you're below the turbo spool RPM. You'll just feel how heavy the eve is.
I just make sure I'm on the right RPM before overtaking. Once you're there, no issue in accelerating quickly. I use the S mode for long driving to keep the RPM higher than usual. Hope this helps.
*ferrarifan,
Ok. Actually I posted din sa FORScan thread regarding the Enhanced Active Park Assist.
I'll ask my follow up questions regarding FORScan there na lang hehe
Heads up mga co-everesters, after 50k pms pinarinig ko sa SA yun intermittent 'krik krik' sound. SA told me na flapper ng a/c yun (recirculate) and that meron na mga nagpaayos nun. Ipa sked ko next time sa kanila for fixing under warranty.
Question mga brother. Naexperience niyo ba na na-stock yung susi at ayaw matanggal? Sa ngayon kasi ayaw matanggal so ginagamit muna namin yung spare key pang lock. Baka dalin namin sa casa sa lunes. Thank you!
Handbrake mo paps nakalagay sa P den shut off engine.. Tapos alisin mo na key..
Sent from my F3212 using Tsikot Forums mobile app
nasa lock position na? 5 position yan.. dapat mag release sa lock position..
