Page 245 of 359 FirstFirst ... 145195235241242243244245246247248249255295345 ... LastLast
Results 4,881 to 4,900 of 7178
    Jan 2013
    #4881
    Quote Originally Posted by fastrider View Post
    I got the aerocover II from Ride Banawe. Cost me 30t, installed in 45 minutes because my bed liner original from thailand (The first batch of xlt rangers have these bed liners. If you have the bedliner that covers the whole bed they have to cut it to install the brackets for the tonneau. The cover is black, lightweight and made of Ultra Violet resistant plastic with good finish. No leaks, perfect alignment, easy to close and open, lockable and a breeze to remove (around 3 minutes only) if you want to load something big and high. Try visiting their Facebook page. Hope this is helpful.
    Thank you fastrider! That was fast and very helpful. Was it bolt-on and no drilling? It should be a perfect fit. However, I got the new bedliner which includes the bedrail. Don't they have a newer model for this para no cutting of liner?
    #4882
    Quote Originally Posted by sprikitix View Post
    Sir sprikitix and fast rider, kindly post po your pictures ng aerocover. I had mind kc installed with a rollover sa carry boy but its not 100% leak/water proof. Planning to change it po. TIA
    Aug 2012
    #4883
    I had mine installed a couple of weeks back, so far so good, no leaks or whatsoever. Bed liner overlaps the bed rail so the fit is perfect. I just don't like the texture of it, but it does serve its purpose.
    Anybody who has installed a hard tonneau from Ride in Banawe? Kmusta naman ang fit? Lapat na lapat ba? Wala bang leaks?
    Nov 2011
    #4884
    Mga bossing napano na yung EB?
    May 2013
    #4885
    Quote Originally Posted by clairenceh View Post
    Same question. Sana meron soon!
    Apr 2012
    #4886
    It is not bolt on. They have to drill a couple of holes to install the 4 brackets. Don't know if they have newer cover to avoid cutting the bed liner.
    Mar 2013
    #4887
    Quote Originally Posted by yggyboy View Post
    o kaya 50 psi pala hangin kaya sigro magaan
    yung wildtrak ko medyo tabingi yung tindig may nakapag paayos kaya sa inyo sa casa?
    Tabingi rin XLT manual ko, sabi nang casa sa akin dahil daw sa locaion nang fuel tank..
    pero ibang ranger ok naman ang tindig.
    Aug 2012
    #4888
    Quote Originally Posted by coachryan View Post
    Sir, could you share the breakdown of the cost pls? (DI, LTO, insurance, chattel mortgage, etc.)
    From what dealership did you get it, and how long did you have to wait?
    also interested here to know.
    thank you
    #4889
    Quote Originally Posted by Tommy24 View Post
    Baka wala nang fuel yung Ranger nila
    Sakin rin tabingi eh. Sige di ako magpapakarga hanggang hindi 1/4 yung laman ng tank, tingnan natin kung papantay.
    #4890
    Hehe sakin din tabingi eh. Baka mas malaki itlog ko sa kaliwa hehe
    Sent from my GT-I9082 using Tapatalk 2
    Apr 2012
    #4891
    Quote Originally Posted by zamoco_08 View Post
    Sir you can check out the facebook page of Ride Offroad they got lots of pictures of aerocover II. Most common problem with rollovers is leakage.
    Jan 2013
    #4892
    Quote Originally Posted by Aleman View Post
    Thanks Aleman. Where is the hinge of your bed cover located? Inside in the center with pin locks or outside on the sides with ring locks?
    Aug 2012
    #4893
    The 2 hinges are located inside the bed at the front most. The hydraulics are mounted somewhere in the middle of the bed. One good thing I have to point out with the texture compared to Carryboy Sport Lid is that, it is less prone to scratches therefore less worries and less maintenance needed. I even tried to stand on top of it and it didn't bend, you have to consider your weight of course, since I weigh only 60kg ...
    The only thing that worries me are the locks, it looks very easy to break. My suggestion is not to leave valuable things at the back when parked for long hours, well that's pretty much basic regardless of what type of ride you have :bwahaha: One more thing to add, is that it also has a battery operated led light, which is very useful. I hope this helps, I was actually at the same kind of dilemma of whether to get a roller lid, canopy or the hard tonneau. It really depends on how you will use it, mine is that I just needed to use the bed just like a trunk of a sedan. The bonus is that as mentioned by fellow T6 owner who had the same installed is that it is very easy to remove.
    Jan 2013
    #4894
    Thanks again Aleman! You gave me all the information I needed. I think you have the better design compared to the one with the hinges outside because it is not prone to rusting. Have you tried removing it? Do you have to lay down to get to the hinge?
    Aug 2012
    #4895
    Yes, you have to crawl inside to get to it, but it's just a clip, which is a breeze to remove. Good thing that the T6 bed is a bit tall. Another thing that made me decide in getting this is because my T6 is color Gray, the black tonneau cover blends well with it. I am planning on having the tonneau cover wrapped by 3m scotchprint but I still have to drop by WINTERPINE to consult them if possible due to its texture....hehehe....
    #4896
    May drilling ba sa body or sa bedliner na plastic ang kabit ng mga arms?
    Aug 2013
    #4897
    Sakin sa left side naman hindi na talaga gumagana..
    Sir clairenceh nasolve ko na po yung horn problem ko sa right side. Di kasi nila naayos sa casa. They again made a report . What i did was, i slide a thin cloth in between the steering wheel and horn switch. Linis linis lang and it did the job. Parang may grease thingy akong natanggal then when i tested it -- ok na kahit mahinang busina. My horn is working well now. No need to pressed hard to horn. D na intermittent yung slight press ko ng busina on my right side. I hope it will work for you ;)
    Sent from my iPhone using Tapatalk 2
    Mar 2007
    #4898
    Quote Originally Posted by Djerms View Post
    wala pong drilling sa body. sa bedliner lang lahat.
    #4899
    Quote Originally Posted by kng200 View Post
    Uy thanks. Yan ang hanap ko.
    Aug 2012
    #4900
    bedliner is the plastic right? Both the bedliner and yung bed ng truck ang may drilling pero sa inner portion sa gilid lang, di kasi clamp-on, kaya it needs drilling.
2012 Ford Ranger
