Page 345 of 359 FirstFirst ... 245295335341342343344345346347348349355 ... LastLast
Results 6,881 to 6,900 of 7178
    #6881
    Quote Originally Posted by cocoy View Post
    just a quick update about that Ford ranger 3.2 4x4 MT.. ford still doesnt know what is wrong with the transmission.. they said that there is some nuts and bolts to be replaced. but the unit has been in Ford alabang for 2 weeks now. i think they have no clue wats wrong with it.
    Major bummer. I hope this problem of yours gets fixed. Just imagine for those paying monthly amortizations tapos tatagal ng 2 weeks or more nakatengga ang sasakyan sa casa. Not to mention the haunting question if the fix is for long term.
    Jun 2009
    #6882
    Is it safe to carry 20bags of cement = 800kg in the rangers bed? How much load can i actually put in it?
    #6883
    Quote Originally Posted by dcph172 View Post
    The Ranger is rated to carry 1,100 kg of load in its bed, so your 800 kg should be fine.
    Jun 2009
    #6884
    ^ thanks for the info. I was worried the 1100kg was pulling capacity and not the actual load i can put in the bed.
    #6885
    The Ranger's towing capacity is 3,500 kg, or roughly 3 sedans. [emoji108]
    #6886
    That would be for the 3.2 model. How about the 2.2 is it the same?
    Jun 2011
    #6887
    one ton lang pala... most of the time pala over loaded ako...!!!
    kaya pala pag mabilis ang takbo ko at may lubak... sumasagad suspension ko sa harap... he.he..
    i can hear a tug sound...
    Feb 2004
    #6888
    Mga boss, I would be taking delivery of a 2.2L Wildtrak on Saturday.
    Meron ba kayo ma suggest na way para mas hindi matagtag yung ride? I'd be coming from a 2008 Honda Civic kasi. First time pickup user. Plus anung ok din na takip para dun sa likod?
    Tsaka kung meron ba ok na rear view camera, na available sa labas?
    Thanks!
    Thanks!
    Mar 2004
    #6889
    If ride comfort was a major concern, you should've gotten the Nissan Navarra with coil spring suspension.
    #6890
    guys just a small update of that Ford ranger 3.2 mt 4x4 that had tranmission problems.. Ford alabang has said that there are 3 bolts on the transmission that has caused that problem.. as for what bolts they are i have no idea..it could be the bolts holding the transmission up.. meaning the problem could be inside the transmission...the ranger pickup though has been in Ford alabang almost a month.
    Feb 2004
    #6891
    It was not really a major concern, I was really after the looks and the ride height hehe. Any means to improve the ride quality would be an added bonus hehe.
    Jun 2011
    #6892
    Quote Originally Posted by Specter View Post
    Thanks!
    Thanks!
    replace oem shocks with dobinsons... more or less will cost you 40k+ front and rear.. with 2.5" lift na din...
    pero malaki ang improvement sa ride comfort... better na cya sa navarra....
    Thanks!
    Thanks!
    Sep 2009
    #6893
    hi guy,just asking for a friend,,, they have a 2 month old ford ranger 3.2 4x4 mt. last night they where driving home and the transmission locked up into first gear. they live in santa roso laguna. they where driving from Silang.. i live in silang so we went to see what could be the problem. after checking out the linkage for the gear lever goin into the tranmission. i didnt see anything usual.. nothing was disconected.. but when i tried shifting to other gears it would not shift.. even when the engine was off and with the clutch down.. the gear lever felt like it would break if i forced it to other gears.. or to shift it to neutral.. finally they decided to drive it to Ford santa rosa in paseo. i just told the driver to freewheel until it would stop and just carry on in first gear slowly until they reach Ford. this was last night at around 10pm..
    this morning they were told that Ford santa rosa doesnt have the tools or the capability to check the Ranger. so they were advised to take it to ford alabang.. with a p5000 fee for taking it there..
    question is now.. with the Ranger clearly still under warranty what rights do they have? and 2nd what could be wrong with such a new car.. Ford Santa rosa mentioned they might have to take down the engine and transmission..and lastly does anyone have any experinced with this problem?
    thank you so much guys..
    typical FORD---Found On the Road Dead.
    Jun 2011
    #6894
    Truckesh--- my ford ka ba?
    Mar 2013
    #6895
    Quote Originally Posted by truckesh View Post
    Fix Or Repair Daily.
    Sep 2009
    #6896
    Not quite a headache for me coz it's a company car Explorer up here in Houston, just waste of time when glitches occur.
    I knew buddy u have a Ranger & we'll compare to my own Jap truck Taco which is more than 7 years now, not bashing ha.
    Aug 2012
    #6897
    Does anybody here has a link on any video showing how to remove/replace the radiator grill?
    #6898
    Quote Originally Posted by Aleman View Post
    Puro plastic gromets lang yan sir. Pull up mo lang yung center pin nung gromet using a slim flat type screw driver and then pull out the whole gromet out. If i remember right there are 8 of them on the top cover. Pag natanggal mo na top plastic cover makikita mo na lahat ng need mo alisin to remove the radiator grill. Installation should just be the reverse.
    Aug 2012
    #6899
    Thanks for the reply, does this mean that once matanggal na yung top plastic cover, all clips sa grill is very much visible?
    #6900
    Yes. Basta if it still does not come out then that means meron pa natitira na di mo nakita. Just do a 360 degree check.
2012 Ford Ranger
