Page 246 of 359 FirstFirst ... 146196236242243244245246247248249250256296346 ... LastLast
Results 4,901 to 4,920 of 7178
    Mar 2007
    #4901
    [QUOTE=Djerms;2222416]Uy thanks. Yan ang hanap ko.
    aeroklass just got mine installed kahapon * winterpine. ok naman pgka install. at bago na pala yung design for ranger kakaiba yung shape hindi lang siya flat tulad naman mga photos sa google(thailand rangers). and just the way i planned, natakpan yung bedliner natin na hindi maganda ang fit.
    #4902
    Quote Originally Posted by Aleman View Post
    bedliner is the plastic right? Both the bedliner and yung bed ng truck ang may drilling pero sa inner portion sa gilid lang, di kasi clamp-on, kaya it needs drilling.
    Oh I see. Thanks.
    Sent from my GT-I9082 using Tapatalk 2
    Jan 2013
    #4903
    Yes, you have to crawl inside to get to it, but it's just a clip, which is a breeze to remove. Good thing that the T6 bed is a bit tall. Another thing that made me decide in getting this is because my T6 is color Gray, the black tonneau cover blends well with it. I am planning on having the tonneau cover wrapped by 3m scotchprint but I still have to drop by WINTERPINE to consult them if possible due to its texture....hehehe....
    Thanks for all your help Aleman! I got my hard tonneau replaced today. From the model with the hinges outside to the model with the hinges inside. The cover they first supplied me was not a prefect fit and there were leaks. They replaced it. No questions asked! Now I'm very happy! Cheers to Ride, Inc.! Cheers to Aleman!
    Jan 2013
    #4904
    [quote=kng200;2222585]
    Quote Originally Posted by Djerms View Post
    Picture naman kng200. How much did it cost?
    Dec 2010
    #4905
    Tested ko na xlt ranger ko in almost all terrain. This past few days I drove more than a thousand kilometers. Here's I can say, it never fails me. Yung 1st gear kahit sabihin na natin may turbo lag from 700-1500rpm, but still kahit within that power band, there is really enough power. Very powerful sya kahit matarik paakyat at madulas, maputik na daan na hirap ang traction, nag wheel spin na nga pero hindi pa nga sya umabot ng 1000rpm kasi sobrang hirap ng daan at paakyat but still it has really enough power.
    Aug 2013
    #4906
    Buenas Tardes! Especially MAPFRE clients! Join and get a chance to win!
    Dec 2012
    #4907
    Guys, would you rather do change oil sa labas than sa casa? Kakilala ko kasi ung gumagawa sa Ford sa place namin, is it the same kung gagawin sa labas and casa? gusto ko kasi maka tipid at ano ang pros and cons if sa labas gagawin?
    Need your opinion asap.
    Thank you
    And btw, wala pa 10k and takbo ng ranger ko , but 6months na. kaya I am asking kung pupunta ko pa po ng casa.
    Dec 2010
    #4908
    Quote Originally Posted by nicenz View Post
    Thank you
    If warranty matters to you then sa casa ka, if you don't care naman na ma void yun, go outside casa. Yun lang.
    #4909
    Thank you
    I did my 10k pms outside casa. I see mpre cons than pros kung tiwala ako sa gagawa. Just buy the oem parts andmake sure the oil is within specs.
    Re warranty, I've called their attention re rusted injectors and all they said was they do not know pa what to do. In short, let it just rust away hehe. To hell with their warranty.
    Recalls on the other hand are served with or without voiding warranty.
    Dec 2012
    #4910
    Bakit hindi mo sila ipahiya dun? Whata shame. tayo may TSB, sila wala? pamuka mo sakanila un baka matakot pa sila sayo. hahah
    Pina check ko ung akin, so far ok panaman wala pang rust. pero kung meron pretending ako na hindi ko alam ng yayari. kung chcharge nila ako nun papakita ko sakanila TSB.
    Thanks for the heads up.
    #4911
    Im sure may tsb sila kaso yan talaga ang badtrip sa kanila, they are liars.
    #4912
    Alam ba ninyo kung saan located ang obd2 port natin?
    Aug 2012
    #4913
    Quote Originally Posted by sprikitix View Post
    Hahaha...I am just a fellow tsikoteer here that is trying to share my experiences, whether bad or good, with my T6. I also am learning a lot from this forum. I hope that we keep this forum going. By the way, you're most welcome sir *SPRIKITIX....
    Dec 2010
    #4914
    Under the driver side coin box. I will install a bluetooth obd2 adaptor tomorrow for the torque pro apps.
    #4915
    Quote Originally Posted by JX290 View Post
    My plan too. Where did u get obd2 scanner?
    Dec 2010
    #4916
    Ebay for around 10usd. Get the mini para magkasya sya dun sa underneath ng coin box. Kasi pag regular size hindi mo na maisara ang coin box.
    Mar 2007
    #4917
    [QUOTE=sprikitix;2222771]
    Quote Originally Posted by kng200 View Post
    35k, i waited for 2 mos, by order kasi(konti lang kasi dumarating so baka maunahan). yes ill post pic soon. i posted pics na rin sa fb ranger club ph.
    #4918
    Sir jx290,
    Pls educate me, para saan po yun obd2? Is it that important to install on our ranger? TIA
    #4919
    :oooh:
    #4920
    Many thanks!
2012 Ford Ranger
