Page 247 of 359 FirstFirst ... 147197237243244245246247248249250251257297347 ... LastLast
Results 4,921 to 4,940 of 7178
    Dec 2010
    #4921
    Quote Originally Posted by zamoco_08 View Post
    Sir jx290,
    Pls educate me, para saan po yun obd2? Is it that important to install on our ranger? TIA
    OBD2 meaning on board diagnostic. Dito kinakabit ang electronic equipment para mabasa lahat na nangyayari sa makina, gaya ng coolant temperature, rpm, boost pessure, oil pressure and so on. Dito rin magbasa ng mga fault codes ng makina at saka pag clear nito, o di kaya pag reset ng ecu. Ngayon pwede na natin ma monitor ang sarili nating makina thru our smartphone. Merong application like torque pro na kayang magbigay ng real time information sa driver. Kailangan lang sa apps na ito ay ang bluetooth device na kinakabit dun sa obd2 port para ma transmit wirelessly dun sa smartphone natin na di na kailangan ang mamahaling gadget na ang casa lang meron. HTH.
    #4922
    Quote Originally Posted by JX290 View Post
    Thank you very much sir, that was informative. You had mentioned that you bought your obd2 in eBay?
    Dec 2010
    #4923
    Yes sir. Mini bluetooth obd2 adaptor. You can bought one also * sulit, pero sobra namang mahal, 2000 pesos so I tried sa ebay.
    #4924
    Ebay for around 10usd. Get the mini para magkasya sya dun sa underneath ng coin box. Kasi pag regular size hindi mo na maisara ang coin box.
    Sir tried searching it sa eBay while ago, Kaso ang dami hehe. Pwede po mahingi exact model/name of the obd2 your using or bought? TIA :-)
    #4925
    Under the driver side coin box. I will install a bluetooth obd2 adaptor tomorrow for the torque pro apps.
    Can u Change the settings of belt minder and km/L with OBD2? What's the most useful function for u?
    May 2010
    #4926
    :oooh:
    Diba dapat "WildTrak?"
    Dec 2010
    #4927
    Quote Originally Posted by A-OK View Post
    No sir, it cannot change settings. Only ford can do that. But it can scan the engine and clear fault codes, this is the most useful function for me. If your check engine is lit alam ko na agad first hand and guessing is prevented before going for repair.
    #4928
    Quote Originally Posted by SiRbossR View Post
    Yes po. Eto pa isa
    Dec 2010
    #4929
    Get the white one. here's the model.
    ELM327 V1.5 Mini Bluetooth OBD2 OBDII OBD Adapter Auto Torque diagnostic Scanner.
    #4930
    Great. Thanks for sharing. Show us your torque pro app in case Meron EB.
    Wanting to change the belt minder, auto open all Window function and km/L settings.
    Apr 2013
    #4931
    Arent the procedures to activate those feature shown in the repair manual?
    Sent from my G-Note 2
    Dec 2012
    #4932
    Please post some picture after you installed it. And thanks for sharing
    And tell us what application and etc did you use.
    #4933
    Meron nga nung dark grey na ranger. Didn't see which dealer it cam from as the conduction written in the plate area is just red fonts. It's a wildtrak btw.
    #4934
    Yes po. Eto pa isa
    This is the new DMAX 2014 model..... Sa gusto nilang tumapat sa ford ranger, they produce their own wildtrak version hehehe :-)
    #4935
    if the all new D-MAX will come here at the Phil. hindi na nila kailangan magsulat ng Wildtrack, malamang Ranger ang mag lagay D-MAX. :banana1:
    #4936
    Quote Originally Posted by jtest View Post
    Afaik, it's already here. Some people spotted them already on the road.
    #4937
    yup. it has been spotted a few times na, also balita eh bandang Nov. or Dec. daw. Maganda ang ranger no if and buts about that. pero maganda din itong new Dmax lowered man o lifted. Pricing na lang ang magiging issue.
    Dec 2010
    #4938
    I have seen it already personally. Walang pagkakaiba halos sa colorado except for the face, and the multimedia head console.
    Jun 2007
    #4939
    Anyone knows how much are the T6 Tail Lights?
    #4940
    Quote Originally Posted by SharkDines View Post
    No idea. But you could call up casa.
2012 Ford Ranger
