Sir zamoco here you will find. This is their reply when I inquired.
Thank you for your interesting in our Ford Ranger.
PR-RANGER8(G) is our latest model with Voice control added. You can see the below link for more information;
?????????????????? FORD RANGER ???? PR-RANGER8(G) - Exclusive - zulex.co.th
You can order directly from us as the exporting price is USD680 per set, with MOQ per order as 4 set
Only one set price is USD750 per set. Please kindly note that this price is excluding the map license and transportation fee.
For deliver to your place, you can check your local express company (TNT, DHL etc.). *And here is for your information to calculate air freight;
1 carton: 2 sets
Net weight: 8 Kg
Gross weight: 9.44 kg
Dimension of carton: 54*38*45(cm)
- Or if you can provide your address and order quantity and we can estimate shipping fee for you.
Should you have any question on our products, please do not hesitate to contact us.
Thank you.
Best regards,
Mary
Oversea Coordinator
Zulex (Thailand) CO., LTD.
Tel: + 662 926 6880
Fax: + 662 926 5559
Mobile: + 6689 780 5660
Email: wilai****.s*zulex.co.th
Website: ?????????????????? | ??????????????????????????????????????????
Does the voice control also control the in car settings like the temperature?
Sent from my G-Note 2
Just saw a white XLT in festival mall. Tinabi ko fortuner namin, ang laki ng lamang sa haba nung ranger. Well, we just sold our fortuner. Planning na kami para bumili ng white XLT. Yahoo!
Guys na encounter nyo na ba mag fog or moist ang windshield nyo? saakin siguro 5 times na tuwing umuulan. napaka hirap maka kita dahil sa moist. ang tagal din nya matanggal... What to do?
Mali timing mo. there are a few reasons why it Normally happens but here's one common reason. This occurs whenever the ECU sense that you are about to stall because of the load you applied to the engine. It Revs the engine a bit to keep it from stalling because modern engine has a fuel cut-off while the engine is decelerating.
in your case, the ecu's anti stall feature took in effect just before you pressed onto the clutch and/or the brakes.
HTH.![]()
Alarm will be activated when the door is opened by the spare key or by force. Here isalso a motion sensor inside the car that will trigger when the alarm is active.
The lights will not blink or confirm if you lock it while there are open doors or hood. Fyi
Sent from my GT-I9082 using Tapatalk 2
Anybody who has installed a hard tonneau from Ride in Banawe? Kmusta naman ang fit? Lapat na lapat ba? Wala bang leaks?
I got the aerocover II from Ride Banawe. Cost me 30t, installed in 45 minutes because my bed liner original from thailand (The first batch of xlt rangers have these bed liners. If you have the bedliner that covers the whole bed they have to cut it to install the brackets for the tonneau. The cover is black, lightweight and made of Ultra Violet resistant plastic with good finish. No leaks, perfect alignment, easy to close and open, lockable and a breeze to remove (around 3 minutes only) if you want to load something big and high. Try visiting their Facebook page. Hope this is helpful.
