[IMG]file:///C:/Users/grey%20luis/Desktop/ranger/ranger1.jpg[/IMG]
two inches taller... installed Ironman Nitro Gas suspension
the coils that made my ride 2 inches taller
with extended u bolts to accommodate the 2 inch lifting block.
Angporma! Saan mo nabili yan bro? Baka pwede yan sa everest gen3? Pa-PM pls.
Sir gumanda ba ride? Magkano inaabot lahat na? Saan kayo nagpabit? Thanks
*CDV, I opted for the nitro gas of the Ironman since I never tried foam cell on shocks. the ride is slightly stiffer than the stock but what's noticeable is the controlled rebound of the shock compared to the stock shock.
BTW the spring rate of my coil is "B", which according to the seller is intended for setups with extra front load(ex. steel bumpers, bushguards etc.).
Any suggestions how to debrand the Ford sign infront (grill) and the chrome badge on the front fender?
Can I use the flat black "car foil"?
Sent from my GT-I9100 using Tapatalk 2
Thank you Sir Zam...am really proud to be owner of this great truck!
it's my first Pick up or UTE as for Australians and BAKKIE for South Africans![]()
I've been driving automatics but I'm so amazed of the 3 modes of the auto tranny specifically the SPORT mode it learns your driving style adapts to different terrain it even senses if you need to engine brake so there's no need to frequently step on the brake pedal even when driving down Kennon road unless you really want to stop or make a sudden stop. When you drive in AUTO mode it's really economical because it doesn't slow down immediately when you let go of the accelerator, hindi sya agad nag-engine brake it just coast so you can just drive along parang ang effect is nag-shift ka sa neutral kung naka-manual tranny ka. Now when you're on MANUAL mode... you're the MAN! Your wish is its command
But my best experience in driving the ranger is in RELAX mode which is AUTO + CRUISE CONTROL. Just drive set the cruise control to the speed limit and cruise along, when the car ahead is slower press CANCEL it will slow down then press RESUME and you're back to the preset speed.
If the 3.2 is "WILDTRAK" and the 2.2 version is "MILDTRAK" our XLT Auto is the "ECOTRAK"derived from Ford's EcoBoost... he, he, he.
A few Rangers on Concept One Wheels - Innovative Technology :
Lupit talaga ng Black Rhino Hard Alloys + Nitto Terra Grappler All Terrain Tires combo!
Ito gwapo! Nitto Dune Grapplers:
sa mga nag palit po ng rims and tires po nila, mag kano niyo po nabenta ung TIRE alone? Balak ko po kasing ibenta ung stock tires ng wildtrak ko po tpos palitan ng nitto terra or dune grappler tires. Magkano din po ba each ng terra at dune grappler?
