Sir nicenz, pwede naman yan if you like the looks of your ranger na macho talaga. Kasi nga mas macho talaga pick up Pag malapad tires.
Pro, at 285 Medyo labas na ng fenders mo ang tires and downside is Pag napa daan ka sa putik or tubig, lahat ng talsik nasa side (body) ng ranger mo which na madumi agad hehe. Not unless naka side fenders ka na :-)
My tire size is 275/55/20, no problem and contented with it :-)
Guys tanung ko lang, nung nakuha nyo ba mga rangers nyo meron ba itong kasamang cover yung ilalim ng hood? Shroud b tawag dun? Yung amin kase wala eh
Salamat po. Actually, 'yung "JJ" po talaga ang gusto naming malaman at kung ano ang epekto nung "offset".
Ang stock tires po ng 2012 Ranger ay 265 x 65 x 17R. Ano po ang specific dimensions ng mags na dapat bilhin
kung ang size po ng tires na ikakabit ay 265 x 50 x 20? Yun po sanang mags na tamang- tama lang para doon sa tires.
TIA
Taken from Technical Information: Wheels and Tires
Rim Contour / Bead Profile Designations:
Wheels will have a letter designation for their contour or the expected tire bead and rim shape.
Some possible contour designations are J, JJ, K, JK, B, P, and D
Common (and generally interchangeable) wheel contour designations are J, JJ, and JK.
J is the most common type for most automotive rims
JJ is common on 4x4 vehicles
Basically the rim contour and bead profile specify the shapes of the rim flange and the bead area.
You generally want to stick with something the same or close to what you have, assuming the same tires.
That is a given tire is made to mount on a certain type of wheel; diameter and contour code being most critical.
For more information, see: Car Bibles : The Wheel and Tyre Bible Page 2 of 4
Question fellow rangers. May nagpakabit na ba sa inyong hardtop bed cover?. Pa share naman ng pics nyo please. Would you recommend customized one rather than Carryboy? Sa Strada club kc may nabasa ako dati na trusted shop owned by one of their members. TIA!
Check mo itong website sir, play and learn hehe
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
