Results 1 to 20 of 3899
    mukhang marami nang supply ng BD28... hehehe :banana2:
    subukan niyo tumawag sa volmax. 2 weeks ago sabi sa akin may bagong dating daw na container e. hindi ko palang nadaanan last week.
    dvldoc
    Hi dvldoc. I need some help here. I would want to run a filter relocation modification BUT the housing for the filter is small. Current or correct filter being used is a bd7160 but gasket diameter for the filter relocation would be able to fit a B2 diameter. Here is the data on the two filters.
    B2:
    Contains: Anti-Drainback Valve
    8 PSID Front End By-Pass Valve
    Descriptions: Dual-Flow Lube Spin-on
    BD7160:
    Contains: 11-17 PSID By-Pass Valve
    I can't remember if I can run a higher or lower psid filter.
    Thanks in advance for your help!
    Dec 2007
    Quote Originally Posted by edtf View Post
    dvldoc
    B2:
    BD7160:
    I think you have your filter number mixed it's not a B2 maybe you mean a BD28. The gaskets on those two are different the thread pitch is the same. It may or may not work due to the gaskets size difference you might have a leak.
    - - - Updated - - -
    dvldoc
    B2:
    BD7160:
Remote bypass oil filtration
