Page 188 of 195 FirstFirst ... 88138178184185186187188189190191192 ... LastLast
Results 3,741 to 3,760 of 3899
    Sep 2013
    #3741
    Ang baldwin meron din made in china like yung mga fuel filter (BF7535, BF7534...etc ) pero ganda pa rin pagkagawa. Sariling planta kasi ng baldwin yung nasa china.
    Sa bosch hindi pa ako nakagamit ng oil filter pero yung subcon na wiper blades ang pangit ng quality.
    May 2005
    #3742
    Quote Originally Posted by joemelr View Post
    How much is the bosch OM-36?
    If the price difference from BD28 is just little, better get the Baldwin na.;)
    Bosch OM 036 - Php 350.
    BD28 - Php 9xx ? ( I think).
    Price is quite far. ry is correct in stating baldwin is 2.5X of the price of OM 036
    Quote Originally Posted by miked View Post
    ganon? made in thailand yun fuel filter ko na bosch.
    Not all Bosch filters are made in the same area. Some are made in Korea, Vietnam, Indonesia and other areas.
    #3743
    Sa baldwin sure ball kaya 10K kms change oil... ;)
    Dec 2009
    #3744
    replaced my fleetguard FS1241 with baldwin BF1249
    the baldwin is longer and without a glass bowl.
    batter filtration,better flow rate and better water separation.
    old
    new
    Mar 2005
    #3745
    Question po about filter size for my Hyundai Santa Fe
    Currently using Mobil 1 Extended Performance Oil Filter for my Hyundai Santa Fe 09 CRDI. Rated siya for 15,000 miles according sa website ng Mobil 1.
    Specs
    Provides long-life performance for today's longer drain intervals
    Effectively removes contaminants, with a 99.6 percentage Multi-Pass Efficiency Rating and an advanced synthetic fiber blend media
    Holds double the contaminants compared to other filters, with 28.0 grams of total capacity
    Withstands nine times normal system operating pressure, for exceptional protection up to 615 pascals per square inch
    Prevents dry starts by eliminating internal leakage during shutdown through the use of a silicone anti-drain back valve (where required by OEM)
    Compared sa OEM Hyundai, mas shorter yung outer diameter niya ng half and inch and about 3/4th inch shorther siya vs OEM pero sa gasket at thyread size same sila ng OEM. Currently been using it for about 5000 kms and so far not seeing any leaks.
    Question ko is since mas maliit yung Mobil 1 kesa OEM oil filter, mas superior pa din ba ang filtering efficiency ng Mobil 1 at mas malaki pa din dirt holding capacity niya vs oem kahit mas maliit body niya?
    #3746
    New Year's gift combo for the 1HD-T courtesy of CB aka Santa Jimny, Santa Fortuner, formerly known as Santa Pajero.
    Apr 2010
    #3747
    Any alternatives for VIC C-226 (oil) and FC-226 (fuel) filters? Medyo hindi widespread yung sa oil filter ko kasi 1-12 UNF ang thread size nya.
    #3748
    Quote Originally Posted by ParticleX View Post
    Have you cross-checked the Baldwin and Fleetguard filter alternatives and checked with the local suppliers?
    Apr 2010
    #3749
    Yes already checked sa Baldwin site, yung seller sa ow el eks does not carry them. Yung fleetguard seller di na nag followup hehe. Sa Bosch naman wala pang reply. Medho malayo kasi Banawe sakin
    Oil filter is Nissan 15208-20N10, fuel is 16403-59E00
    #3750
    ^ Have you tried checking with Traczone?
    Oct 2009
    #3751
    Mas ok bayan sa oem?
    Jul 2013
    #3752
    Guys,
    I live in the province and I want to get a Baldwin (or even Fleetguard or any good oil filter) for my Innova.
    Do you know any seller/supplier who can ship the item even at my expense?
    Someone contacted me (also a seller in olx) but of course, like everyone else, I want to make sure his stuff are genuine.
    Thanks!
    (Any suggested physical store is also appreciated especially near Alabang or Calamba Area)
    Jul 2013
    #3753
    Double post.
    #3754
    Quote Originally Posted by harold13 View Post
    Way better than OEM!
    Baldwin user since 2013
    Mar 2005
    #3755
    Change oil sa bosch centers. Sure na bosch orig ang lalagay nila
    May 2009
    #3756
    tumutulo na yung fleetguard LF3564 ng kabayo ko after 8k kms. halata na ang drips pero di naman ganun kalakas. hindi kagaya dati na weeping leaks.
    bumili nako bosch OM036 (made in vietnam) pamalit sa fleetguard. baldwin subukan ko sa susunod kung di ko pa mabenta kabayo ko. kung me baldwin lang sa kapitbahay e yun na.
    May 2009
    #3757
    tumutulo na yung fleetguard LF3564 ng kabayo ko after 8k kms. halata na ang drips pero di naman ganun kalakas. hindi kagaya dati na weeping leaks. ibinenta ko pa naman yung isa pang stock ko na fleetguard filter sa pinsan ko na may L3. kung ganun din ang mangyayari sa van ng pinsan ko e sadyang may quality issue yung batch na yun ng fleetguard.
    bumili nako bosch OM036 (made in vietnam) for P325.00 pamalit sa fleetguard. baldwin subukan ko sa susunod kung di ko pa mabenta kabayo ko. kung me baldwin lang sa kapitbahay e yun na.
    pumino naman ng husto ang andar once na nagwarm-up na magmula fleetguard gamit ko. maalog nga lang talaga kapag malamig.
    Nov 2013
    #3758
    This is the Baldwin oil filter for the corolla altis 10.5 and 11th generation (year 2011 to present)
    May 2009
    #3759
    mga chief! ano cross ref ng mga sumusunod na filter sa baldwin:
    1. Oil filter C512
    2. Fuel filter FC208
    Isuzu pickup ito.
    kung may seller man dito sa forum (thread) na ito e pakipm na lang sakin.
    salamats.
    1. Oil filter C512
    Isuzu pickup ito.
    salamats.
    Nov 2013
    #3760
    BD7028 can be use for newer montero strada 4D56 models.
    Bigger and better than BD28
    BD7028 can be use for newer montero 4D56 models.
Remote bypass oil filtration
