BD7029
Thread: M24 x 1.5
O.D.: 3 31/32 (100.8)
Length: 4 27/32 (123.0)
BD7028
Thread: M26 x 1.5
O.D.: 4 1/4 (108.0)
Length: 5 27/32 (148.4)
We recently changed the oil in our Grandia (2.5 D4d) and i noticed that the rubber gasket may have failed on the BT223, or the Toyota mechanic who did the last oil change miffed up the install. The filter was on for roughly a year and two months and 6,000kms (Toyota FS). There were no visible leaks in the engine bay area or where we park the car (save for some oil residue where the filter housing is) and we had to add around half a liter of oil late last year.
Pag uneven na ang distance ng media pleats at bended pa, as can be seen sa picture above, clogged na media, hirap na pass ang oil, baka malapot na.
Ilan kms used ang filter?
Posted via Tsikot Mobile App
8500 kms
used with Idemitsu Extreme Touring 15W-40 DH-1 (TBN 13.2) + Liquimoly Mos2 Oil Additive
Madulas na madulas pa ang langis...ganda pa ng consistency.
Dubious B109 ito. Kasi cross ng B109 is Fleetguard LF 3433 and Vic C503. At that time bumili po ako kay Volmax, di ko alam ang cross ng ng C512 na para po sa crosswind ko na 2004 manual. Eto ibinigay sakin kasi sabi dun kasukat ng C512...
So kala ko po ok na. Ng madaan ako sa 8th st new manila...bumili ako reserba na fleetguard LF3433 kasi ng icheck ko nga po cross ng B109...LF3433 ang lumabas. Ng pagbili ko..aba...malaki masyado ang LF3433 para sa akin. Nagulat po ako. Pero pinaabot ko pa rin 8500 kms. Kasi ok na ok ADBV ni "B109". Patay agad ang oil lamp indicator. Kaso ng binuksan ko kanina....masyadong maluluwang ang paper media.
Took sample of the oil for UOA. May pang check isang tropa sa Team Isuzu Pilipinas.
Nakakadala....mag Tokio Roki Isuzu na lang ulit ako....
Nagpapalusot pa rin ata ng pekeng baldwin si V
May print ba ng lot code sa taas ng filter?
Sent from my Nexus 5 using Tsikot Forums mobile app
Mga sir may tanong po ako tungkol sa baldwin oil filters magkaiba ba ang application ng full flow lub spin-on at dual flow lub spin-on? Anung pag kakaiba nila at anung system sila apllicable? maraming salamat sa sasagot.
Your filter's bottom plate looks like this in the pic so its likely genuine. Did it come with a box ? Should not be shrink wrapped.
This is the fake. Notice its shorter and fatter. Different looking font used. Even the Baldwin is a bit off in some areas. The bottom plate would like the VIC. Notice the shrink wrap, which is not normal for this type of Baldwin filter.
Iba nga ang itsura ng B109 sa itaas compared dun sa isa, halata sa print ng B109, spacing is different, pero may nabili ako B178, shrink wrapped siya pero genuine naman.
mga filter gurus, meron na ba Baldwin equivalent yung fuel filter element type ng Montero 2012 models part no. 1770A223? baka may nakahanap na diyan. TIA
filter casing
filter element
