Page 180 of 195 FirstFirst ... 80130170176177178179180181182183184190 ... LastLast
Results 3,581 to 3,600 of 3899
    May 2004
    #3581
    Quote Originally Posted by johnjoseph View Post
    Bro, baka BD7028 ang hanap mo? Kung wala makita, BD28 ay pwede din.
    Posted via Tsikot Mobile App
    BD7029 sir for 1kzte engine.
    Nov 2013
    #3582
    BD7029
    Thread: M24 x 1.5
    O.D.: 3 31/32 (100.8)
    Length: 4 27/32 (123.0)
    BD7028
    Thread: M26 x 1.5
    O.D.: 4 1/4 (108.0)
    Length: 5 27/32 (148.4)
    Sep 2008
    #3583
    Sir, do you sell baldwin oil filters?
    Quote Originally Posted by Baldwinoilfilte View Post
    BD7029
    Thread: M24 x 1.5
    BD7028
    Thread: M26 x 1.5
    O.D.: 4 1/4 (108.0)
    Apr 2012
    #3584
    Canister type ba oil filter mo or element type na?
    meron ka na ba bro ng element type na Baldwin (or equivalent) para sa montero gtv 2012 model? TIA
    Jan 2008
    #3585
    Im selling Baldwin oil filter B1431. (longer version of B1402) Will fit civic, city, jazz, crv, cr-z, accord, odyssey... (B1431 will also fit mitsubishi, hyundai, nissan, subaru, )
    Store name is Mr Liempo located at guirayan street barangay dona imelda quezon city. Beside mezza residence near SM sta mesa. (Store hours: 7am - 11pm)
    Im also selling fleetguard and donaldson counterpart.
    Globe - 0917-902-85-70
    Sun - 0942-598-5338
    Im also selling Baldwin for Toyota and Ford gas engine (vios, altis, old corolla, innova, fiesta, focus, explorer, escape)
    Bro do you have B243? Are you limited to oil filters?
    #3586
    We recently changed the oil in our Grandia (2.5 D4d) and i noticed that the rubber gasket may have failed on the BT223, or the Toyota mechanic who did the last oil change miffed up the install. The filter was on for roughly a year and two months and 6,000kms (Toyota FS). There were no visible leaks in the engine bay area or where we park the car (save for some oil residue where the filter housing is) and we had to add around half a liter of oil late last year.
    Sep 2013
    #3587
    Ito yung post ni dvldoc na tinutukoy ko at advice din ng mga experto sa bob is the oil guy forum.
    Since this gets ask so much just want to break it down to it's simplest form. You should be running oil based on your climate if you look in your owners manual you will see a chart what what type of oil you should use in what climate. But here is the simplest break down I can give.
    The recommended temperature range are as follows
    10w30: -13 F to 100 F (-25Celsius to 38Celsius)
    10w40: -13 F to no limit (-25Celsius to no limit)
    In other words the difference between the two oils if you are hesitating in switching over is that, the 10w40 has same performance at low temperatures, but works well also above 38C/100F. Your vehicle will experience above 38C in Manlia trafffic meaning 30 weight oil will break down quicker and provide less protecton. But if you live someplace like Baguio you can run 30 weight oil year around.
    #3588
    photo credit to andongskee ok TIP Baldwin disected bought from Volmax...
    Whats your opinion guys
    Aug 2013
    #3589
    Pag uneven na ang distance ng media pleats at bended pa, as can be seen sa picture above, clogged na media, hirap na pass ang oil, baka malapot na.
    Ilan kms used ang filter?
    Oct 2011
    #3590
    p1370909_1.jpg8500 kms
    used with Idemitsu Extreme Touring 15W-40 DH-1 (TBN 13.2) + Liquimoly Mos2 Oil Additive
    Madulas na madulas pa ang langis...ganda pa ng consistency.
    Dubious B109 ito. Kasi cross ng B109 is Fleetguard LF 3433 and Vic C503. At that time bumili po ako kay Volmax, di ko alam ang cross ng ng C512 na para po sa crosswind ko na 2004 manual. Eto ibinigay sakin kasi sabi dun kasukat ng C512...
    So kala ko po ok na. Ng madaan ako sa 8th st new manila...bumili ako reserba na fleetguard LF3433 kasi ng icheck ko nga po cross ng B109...LF3433 ang lumabas. Ng pagbili ko..aba...malaki masyado ang LF3433 para sa akin. Nagulat po ako. Pero pinaabot ko pa rin 8500 kms. Kasi ok na ok ADBV ni "B109". Patay agad ang oil lamp indicator. Kaso ng binuksan ko kanina....masyadong maluluwang ang paper media.
    Took sample of the oil for UOA. May pang check isang tropa sa Team Isuzu Pilipinas.
    Nakakadala....mag Tokio Roki Isuzu na lang ulit ako....
    Nagpapalusot pa rin ata ng pekeng baldwin si V
    #3591
    May print ba ng lot code sa taas ng filter?
    Sent from my Nexus 5 using Tsikot Forums mobile app
    Sep 2010
    #3592
    Mga sir may tanong po ako tungkol sa baldwin oil filters magkaiba ba ang application ng full flow lub spin-on at dual flow lub spin-on? Anung pag kakaiba nila at anung system sila apllicable? maraming salamat sa sasagot.
    May 2005
    #3593
    Your filter's bottom plate looks like this in the pic so its likely genuine. Did it come with a box ? Should not be shrink wrapped.
    This is the fake. Notice its shorter and fatter. Different looking font used. Even the Baldwin is a bit off in some areas. The bottom plate would like the VIC. Notice the shrink wrap, which is not normal for this type of Baldwin filter.
    Aug 2013
    #3594
    Iba nga ang itsura ng B109 sa itaas compared dun sa isa, halata sa print ng B109, spacing is different, pero may nabili ako B178, shrink wrapped siya pero genuine naman.
    Apr 2012
    #3595
    mga filter gurus, meron na ba Baldwin equivalent yung fuel filter element type ng Montero 2012 models part no. 1770A223? baka may nakahanap na diyan. TIA
    filter casing
    filter element
    Oct 2011
    #3596
    Yep meron po printdode sa ibabaw...11 digits...plus made in USA
    Came with a box and not shrink wrapped.
    Yun dun ok. Pero po kasi yung pleats nya parang uneven plus ang lalaki ng spaces.
    Oct 2011
    #3597
    ok po kaya to?...nilagyan ko magnet sa ibabaw yung filter ko.
    Quote Originally Posted by andongskee View Post
    Yup, that is good. Asan ka nakakuha nang ganyang kalaking magnet?
    Jul 2011
    #3599
    eto nakita ko lang sa sulit ata
    Buy NdFeb Neodymium
    #3600
    earth magnet, mas maganda, ang liit pa
Remote bypass oil filtration
