Results 3,421 to 3,430 of 3899
September 16th, 2013 10:23 AM #3421
Browsing the Baldwin eCatalog looking for the biggest oil filter that can fit the space in my 2nd gen 4AFE , come across this B1416 oil filter, 3/4 - 16 thread, OD = 73.8mm, L = 123 mm with ADV, BPV pressure of 14 PSID and "Front End Check Valve" . My query is the FECV, what is it for? I'm using the principle "the biggest available filter that will fit at the right price". Using B131 for two weeks now.
- Sep 2013
- 630
September 17th, 2013 01:38 PM #3422Sino mas ok sa dalawa?
B-179
-Descriptions: Full-Flow Lube Spin-on
Contains: Anti-Drainback Valve
8 PSID By-Pass Valve
Fits: Honda Automotive; Kubota, Yanmar Engines
Replaces: Kubota 70000-15241; Transicold 2535206; Yanmar 124450-35100
Thread: M20 x 1.5
O.D.: 3 (76.2)
Length: 2 27/32 (72.2)
I. Gskt.: [1] Included
UPC: 791440002234
B-1402
-Descriptions: Lube Spin-on
14 PSID By-Pass Valve
Fits: Dodge, Eagle, Ford, Honda, Infiniti, Mazda, Mitsubishi, Nissan, Plymouth Automotive
Replaces: Chrysler MD135737; Ford F32Z-6731-A; Mazda JEYO-14-302; Nissan 15208-31U00
Thread: M20 x 1.5
O.D.: 2 9/16 (65.1)
Length: 3 1/2 (88.9)
Related To: B1400 (Short Version)
B1431 (Long Version)
UPC: 791440012059
September 17th, 2013 03:44 PM #3423
If its for a Honda, then its B1402, which is the exact dimension as the Honda filter. More importantly the rubber gasket are an exact match as well.
You can go for longer and wider filter as long as the rubber gasket matches the one installed in your ride. Also consider if the added dimension of the filter will still allow for easy access and installation in the engine bay.
September 17th, 2013 04:01 PM #3424
- Sep 2013
- 630
September 17th, 2013 04:49 PM #3425
September 17th, 2013 05:02 PM #3426
B131 is wider than BT223 pala pero almost same height, mas mura din pala BT223. Hindi ata puwede sa toyota 4cycle engine ang B131.
baldwin bt223, full-flow lube spin-on
baldwin b131, full-flow lube spin-on
September 17th, 2013 05:37 PM #3427
I measured the filter space of my 4AFE, found out I can fit a 77mm diameter x 130mm long oil filter in it, no problem with the heat shield sa ilalim ng manifold. As per Baldwin catalog, pwede na ang B143 full flow spin on lube filter, diameter = 76.2mm, length = 129.4mm with exact match ng gasket, diameter = 65mm. Sa OEM filter, 3.3lts ang oil capacity, siguro, dito sa B143, konti na lang matira sa isang gallon. Sure win sa 10k kms + OCI ito. Regarding the price, a little pricier than BT223 but look at the size naman.
BTW, Ry, B131 ang nakakabit sa 4AFE ko ngayon . . . satisfied na ako but I want the biggest I can fit in it.
- Sep 2013
- 630
September 18th, 2013 04:39 PM #3428Mas ok ba pag mas wider oil filter?
Pero bakit mas mataas price pag pahaba?
September 18th, 2013 10:15 PM #3429
For me, I like the biggest in diameter and longest that can fit sa space with consideration sa diameter ng gasket, not much bigger sa OEM. Napansin ko sa pricing, mahal ang intended for fuel (BF) at dual flow (BD), ang mura yun sa hydraulic/transmission (BT) kung compare mo sizes (length at OD) with each other, hindi ko napansin kung wider ay lower priced sa longer ones. Minsan, supply and demand din affect the pricing.
- Sep 2012
- 32
Because pinoy mentality. Not surprising.
