Page 172 of 195 FirstFirst ... 72122162168169170171172173174175176182 ... LastLast
Results 3,421 to 3,440 of 3899
    Aug 2013
    #3421
    Browsing the Baldwin eCatalog looking for the biggest oil filter that can fit the space in my 2nd gen 4AFE , come across this B1416 oil filter, 3/4 - 16 thread, OD = 73.8mm, L = 123 mm with ADV, BPV pressure of 14 PSID and "Front End Check Valve" . My query is the FECV, what is it for? I'm using the principle "the biggest available filter that will fit at the right price". Using B131 for two weeks now.
    Sep 2013
    #3422
    Sino mas ok sa dalawa?
    B-179
    -Descriptions: Full-Flow Lube Spin-on
    Contains: Anti-Drainback Valve
    8 PSID By-Pass Valve
    Fits: Honda Automotive; Kubota, Yanmar Engines
    Replaces: Kubota 70000-15241; Transicold 2535206; Yanmar 124450-35100
    Thread: M20 x 1.5
    O.D.: 3 (76.2)
    Length: 2 27/32 (72.2)
    I. Gskt.: [1] Included
    UPC: 791440002234
    B-1402
    -Descriptions: Lube Spin-on
    14 PSID By-Pass Valve
    Fits: Dodge, Eagle, Ford, Honda, Infiniti, Mazda, Mitsubishi, Nissan, Plymouth Automotive
    Replaces: Chrysler MD135737; Ford F32Z-6731-A; Mazda JEYO-14-302; Nissan 15208-31U00
    Thread: M20 x 1.5
    O.D.: 2 9/16 (65.1)
    Length: 3 1/2 (88.9)
    Related To: B1400 (Short Version)
    B1431 (Long Version)
    UPC: 791440012059
    May 2005
    #3423
    If its for a Honda, then its B1402, which is the exact dimension as the Honda filter. More importantly the rubber gasket are an exact match as well.
    You can go for longer and wider filter as long as the rubber gasket matches the one installed in your ride. Also consider if the added dimension of the filter will still allow for easy access and installation in the engine bay.
    #3424
    Quote Originally Posted by johnjoseph View Post
    for Toyota 4cylinder sir usually BT223 ginagamit namin dito sa tsikot.
    Sep 2013
    #3425
    Yung b-179 mas wider at mas cheaper sa b1402.
    B131 is wider than BT223 pala pero almost same height, mas mura din pala BT223. Hindi ata puwede sa toyota 4cycle engine ang B131.
    baldwin bt223, full-flow lube spin-on
    baldwin b131, full-flow lube spin-on
    Aug 2013
    #3427
    I measured the filter space of my 4AFE, found out I can fit a 77mm diameter x 130mm long oil filter in it, no problem with the heat shield sa ilalim ng manifold. As per Baldwin catalog, pwede na ang B143 full flow spin on lube filter, diameter = 76.2mm, length = 129.4mm with exact match ng gasket, diameter = 65mm. Sa OEM filter, 3.3lts ang oil capacity, siguro, dito sa B143, konti na lang matira sa isang gallon. Sure win sa 10k kms + OCI ito. Regarding the price, a little pricier than BT223 but look at the size naman.
    BTW, Ry, B131 ang nakakabit sa 4AFE ko ngayon . . . satisfied na ako but I want the biggest I can fit in it.
    Sep 2013
    #3428
    Mas ok ba pag mas wider oil filter?
    Pero bakit mas mataas price pag pahaba?
    Aug 2013
    #3429
    Quote Originally Posted by chookchakchenes View Post
    For me, I like the biggest in diameter and longest that can fit sa space with consideration sa diameter ng gasket, not much bigger sa OEM. Napansin ko sa pricing, mahal ang intended for fuel (BF) at dual flow (BD), ang mura yun sa hydraulic/transmission (BT) kung compare mo sizes (length at OD) with each other, hindi ko napansin kung wider ay lower priced sa longer ones. Minsan, supply and demand din affect the pricing.
    Sep 2012
    #3430
    Anyone still looking for Baldwin BD28?
    #3431
    Quote Originally Posted by Javonito View Post
    nagsawa na kami sa kakaantay. nakakawalang gana na haha Bosch na gamit ng karamihan. yung iba kanya kanyang source na sa US. ang mahal kasi ng benta ng mga resellers.
    May 2010
    #3432
    +1 sa bosch for being readily available
    Sep 2012
    #3433
    How much na ba ang pasa ng mga resellers natin mga sir? I am looking for Baldwin fuel filter for mitsubishi adventure.
    Jul 2011
    #3434
    san nakakabili ng bosch filters? magkano filter for honda?
    Sep 2012
    #3435
    Guys, How much is the BD28 baldwin oil filter?
    Yung bd28 mo dapat sakto sa advie.
    #3437
    are you a reseller sir? SRP is more or less 765 pesos each. resellers sell it at a higher price. but supply is scarse
    Quote Originally Posted by s10pao View Post
    sa mga Bosch centers sir. sa Banawe meron, sa Binondo meron din. but for honda, ok naman supply ng Baldwin. get Baldwin nalang.
    Sep 2012
    #3438
    I am planning to sell BD28 kaya lang hesitant ako i discuss here sa thread baka may maviolate ako na rules. I will try to beat yung price ng reseller. Naka tsamba ako before sa Volmax ng BD28 and i am using it now, after 1000 km still hindi pa umitim yung oil ko (Delo 400). So now naghahanap ako naman ng Baldwin Fuel filter kumbaga combo finish na pure baldwin ang gamit ko even air filter kung may available why not.
    Sep 2012
    #3439
    Yes sir sakto naman yung BD28 ko. So far sir Ry_Tower hindi pa maitim ang oil ko after running 1000 km
    Jun 2005
    #3440
    sir ask sana ako if how much ang oem oil filter for Mitsu 4D56 MD069782?
Remote bypass oil filtration
