Originally Posted by
number001
If its for a Honda, then its B1402, which is the exact dimension as the Honda filter. More importantly the rubber gasket are an exact match as well.
You can go for longer and wider filter as long as the rubber gasket matches the one installed in your ride. Also consider if the added dimension of the filter will still allow for easy access and installation in the engine bay.
