okay thanks dvldoc.
Guys i still have one piece of bd28... Pm nyo ako if interested...
Nag iisa na lang... Sayang naman, matatagalan pa uli bago meh dumating..
Anyone interested with BD28? I have three available. PM me.
Sorry OT
Hehe...got 2 LF3564 bought from filterbarn US, PM me for those who want it...hindi kasya sa rig ko tumatama sa intercooler hose kasi...mas wider sya compared sa BD28![]()
dvldoc
Hi dvldoc. I need some help here. I would want to run a filter relocation modification BUT the housing for the filter is small. Current or correct filter being used is a bd7160 but gasket diameter for the filter relocation would be able to fit a B2 diameter. Here is the data on the two filters.
B2:
Contains: Anti-Drainback Valve
8 PSID Front End By-Pass Valve
Descriptions: Dual-Flow Lube Spin-on
BD7160:
Contains: 11-17 PSID By-Pass Valve
I can't remember if I can run a higher or lower psid filter.
Thanks in advance for your help!
I think you have your filter number mixed it's not a B2 maybe you mean a BD28. The gaskets on those two are different the thread pitch is the same. It may or may not work due to the gaskets size difference you might have a leak.
- - - Updated - - -
Sorry incomplete info. Thread pitch will not matter and I know filters have different pitch. The relocator has replaceable pedestal (I can't remember what you call the thing you screw your filter on.) so I can use either pitch what I need is for the gasket to hit the lip. The b2 seals on the lip well but has a lowered psid. You think I can use the b2 to replace the original filter?
Sent from my GT-I9100 using Tapatalk 2
guys tunay ba delvac1 sa cashncarry? 440php lang kasi.. parang cheaper pa sa mga alam kong stores sa us..
pag sa us.. saan store po ba dapat bibili ng synthetic oil? hehe
ano po good for value oil mabili ngayon mineral or synthetic is fine... for diesel
sa lahat kasi na sasakyan namin i use revx or superdiesel oil... ok naman and walang problema.. kayalang medyo napaisip ako lagyan ng cheap oil yung new diesel ng dad ko.. hehe
sir ry.. yes yun nga.... tunay na yun sa halagang 440php? maganda po yun? real synthetic po ba yun.. hehe mga oil labels kasi natin ang gulo.. hehe minsan nakasulat synthetic blend yun pala semi synthetic lang.. hehe
pag bd28 + synthetic pwede na mag 10tkms until next change oil?
ano po ba free sa casa 1st 1km checkup lang or 1t and 5tkm checkup? hehe thanks
