Page 150 of 195 FirstFirst ... 50100140146147148149150151152153154160 ... LastLast
Results 2,981 to 3,000 of 3899
    Jul 2012
    #2981
    okay thanks dvldoc.
    Dec 2009
    #2982
    Guys i still have one piece of bd28... Pm nyo ako if interested...
    Nag iisa na lang... Sayang naman, matatagalan pa uli bago meh dumating..
    May 2005
    #2983
    Anyone interested with BD28? I have three available. PM me.
    Sorry OT
    Jan 2011
    #2984
    Hehe...got 2 LF3564 bought from filterbarn US, PM me for those who want it...hindi kasya sa rig ko tumatama sa intercooler hose kasi...mas wider sya compared sa BD28
    #2985
    mukhang marami nang supply ng BD28... hehehe :banana2:
    #2986
    subukan niyo tumawag sa volmax. 2 weeks ago sabi sa akin may bagong dating daw na container e. hindi ko palang nadaanan last week.
    #2987
    dvldoc
    Hi dvldoc. I need some help here. I would want to run a filter relocation modification BUT the housing for the filter is small. Current or correct filter being used is a bd7160 but gasket diameter for the filter relocation would be able to fit a B2 diameter. Here is the data on the two filters.
    B2:
    Contains: Anti-Drainback Valve
    8 PSID Front End By-Pass Valve
    Descriptions: Dual-Flow Lube Spin-on
    BD7160:
    Contains: 11-17 PSID By-Pass Valve
    I can't remember if I can run a higher or lower psid filter.
    Thanks in advance for your help!
    Dec 2007
    #2988
    Quote Originally Posted by edtf View Post
    dvldoc
    B2:
    BD7160:
    I think you have your filter number mixed it's not a B2 maybe you mean a BD28. The gaskets on those two are different the thread pitch is the same. It may or may not work due to the gaskets size difference you might have a leak.
    - - - Updated - - -
    dvldoc
    B2:
    BD7160:
    #2989
    - - - Updated - - -
    Sorry incomplete info. Thread pitch will not matter and I know filters have different pitch. The relocator has replaceable pedestal (I can't remember what you call the thing you screw your filter on.) so I can use either pitch what I need is for the gasket to hit the lip. The b2 seals on the lip well but has a lowered psid. You think I can use the b2 to replace the original filter?
    Sent from my GT-I9100 using Tapatalk 2
    #2990
    Quote Originally Posted by tuazon7 View Post
    bro nakunan mo ba ng picture yung LF na sasayad sa hose?
    my 2 boxes(24pcs)of bd28 naman sold out din. good kung mgkakasupply sa volmax, para hindi na ako mahirapan magparating
    Dec 2007
    #2991
    The B2 is not a dual flow filter it's a full flow. They way you can tell this also on Baldwin part numbers is the D in the part number means dual flow.
    #2992
    thanks!! dvldoc
    Jan 2011
    #2993
    Quote Originally Posted by zix888 View Post
    bro walang pics mejo mahirap sa ilalim ng sasakyan pero it is really more sa diameter ng LF than its length kaya nasayad...
    #2994
    alright bro, so bd28 pala talaga
    #2995
    guys tunay ba delvac1 sa cashncarry? 440php lang kasi.. parang cheaper pa sa mga alam kong stores sa us..
    pag sa us.. saan store po ba dapat bibili ng synthetic oil? hehe
    ano po good for value oil mabili ngayon mineral or synthetic is fine... for diesel
    sa lahat kasi na sasakyan namin i use revx or superdiesel oil... ok naman and walang problema.. kayalang medyo napaisip ako lagyan ng cheap oil yung new diesel ng dad ko.. hehe
    Quote Originally Posted by AC View Post
    Yung Mobil 1 TDT ba yan? Ganyan nga price niyan afaik.
    Nov 2012
    #2997
    Doc,
    I was testing this new oil, ENOC Vulcan 770x - CI4, CH4, SL. Its Made In saudi Arabia. I was not able to get more DATA like Zinc Content and whether it has been Reformulated to get CI4 Plus.
    Have you come across this Oil and any info on it?
    Thanks.
    The Fleetguard is 30 microns * 95% efficiency.
    Using a longer version just depends if you have space which in a Ranger you should just make sure the filters have the same gasket, and close to the same bypass valve if it has one.
    Rangers are particular dirty so I would stick with 10000klm max. The only way to squeeze extra life out of oil is to do a EGR delete and Oil catch can, that will get you your 12000klm. Delo 400 will easily go this distance.
    #2998
    sir ry.. yes yun nga.... tunay na yun sa halagang 440php? maganda po yun? real synthetic po ba yun.. hehe mga oil labels kasi natin ang gulo.. hehe minsan nakasulat synthetic blend yun pala semi synthetic lang.. hehe
    pag bd28 + synthetic pwede na mag 10tkms until next change oil?
    ano po ba free sa casa 1st 1km checkup lang or 1t and 5tkm checkup? hehe thanks
    Dec 2007
    #2999
    Quote Originally Posted by wkk888 View Post
    Doc,
    Thanks.
    Can't find it either but if you stick with CI-4 Then there should be plenty of ZDDP
    Tama nga pricing niyan at FS na rin yan. Sa bd28 + synthetic oil yakang-yaka na talaga 10K COI.
Remote bypass oil filtration
