Page 140 of 195 FirstFirst ... 4090130136137138139140141142143144150190 ... LastLast
Results 2,781 to 2,800 of 3899
    #2781
    Quote Originally Posted by Rocko24 View Post
    Correct. The focus of these stores is for fleet and heavy equipment customers. For these types of equipment, the filters are both more expensive and customers are more discriminating. Plus the filters are changed more frequently. It may surprise a lot of people as to how often the filters are changed. For example, for a Komatsu HD325-6 mining dump truck, the recommended replacement interval of the oil filter is 250 hours. If the truck runs 20 hours a day, the filter has to be changed every 13 days.
    Probably cause those engines are heavy duty engines?
    Talagang continuous usage lang talaga yan. Mining equipments eh 24 hours halos, breakdwon lang pahinga. Genset ganun din, tuloy-tuloy kasi.
    #2783
    Me nag try na ba mag petition sa Handyman or ACE hardware para sila na lang mag paka hirap bumili ng fleetguards and baldwins para saten?
    #2784
    and mainit yata sobra oil nila. cause hindi naman sila gumagalaw. kulang siguro sa air flow hehe naisip ko lang.
    #2785
    baka tad tad naman ng aux fan yung rad nila?
    May 2005
    #2786
    Quote Originally Posted by bayen View Post
    Could anyone tell me whats the biggest oil filter you can fit on an innova diesel (d4d engine)?
    Can any of the following fit?
    Fleetguard LF689, Baldwin B233 equivalent
    Fleetguard LF551A, Baldwin's B2 equivalent
    Fleetguard LF3314, Baldwin B118
    I have both 2KD-FTV (D-4D)in the Innova and a 2TR-FE (VVT-i) in the Fort.
    The Innova is only a year old so its still strictly Toyota Casa serviced for warranty purposes. I have checked under the hood again just now. You can fit any long filter. Its the width that you might have problems with. Will it fit ? Check the provided photo I took above. The LF3487 is ideal bec. of its filter area size and its use of synthetic filtration material (microglass).
    #2787
    Heavy equipment move at low engine speeds, carrying loads, for long hours under dusty conditions most of the time.
    Yeah, recipe for early COI talaga and kaya may need for a heavy duty filter.
    Try ko sa Handyman dito sa amin if ma-haggle ko. I'll ask for Baldwin na lang kasi mukhang mas malapit source natin, Singapore.
    Jan 2012
    #2789
    Cool! thanks for providing the photo above. gives us very good idea how puny the OEM Oil filter
    The diameter of the gasket am sure are the same for the Toyota OEM, BT223, LF3487
    What am not sure about here is the circumference of the oil filter mounting area on the 2KD-FTV (D-4D) & 2TR-FE (VVT-i) engines ... Will it fit a 3.7 incher OD filter?
    The filters i have below:
    Outer Diameter (OD) - are from 3.6in - 3.7 inches. Will it fit or not?
    Thanks
    #2790
    Thanks
    From what I remember from before, only BT223 will fit the d4d engine cause of the tight space. On the other hand, a bigger B233 will fit innova gas. I tried it on our innova almost 10months ago.
    May 2005
    #2791
    Yes all have same gasket diameter and there was lots of space in terms of width and length in the 2TR-FE VVT-i engine so it worked well.
    Lots of space in terms of width and length in the 2TR-FE VVT-i engine so it worked well. 2KD-FTV might have problems in terms of width since there is not so much horizontal space down there. Not sure though since I never tried the LF3487 with the D-4D.
    The following filter when compared to LF3487:
    LF551A - almost the same dimensions. Superceded by LF3487. So still better to get LF3487.
    LF689 is shorter in height or length. and uses slightly inferior filter material (paper) than LF3487. So still better to get LF3487.
    LF3314 - slightly taller and narrower than LF3487. Try this one if there are fitting issues with the LF3487.
    Jan 2012
    #2792
    awesome!
    thanks for the quick feedback CB. appreciate it bro.
    #2793
    awesome!
    Just to be clear, we only have the gas variant of innova. I only remember reading about the d4d also here in tsikot.
    Apr 2012
    #2794
    anyone who has a Baldwin BT223 filter to spare?...kindly pm me...TIA
    I was able to negotiate with our suking auto shop that they try to get bosch oil filters for our fleet instead of Vic. Hopefully the price will be close to Warren's para okay na okay. Pati yung sa fuel at oil filter ko damay na din. Hirap talaga sa baldwin at fleetguard eh. Sa Handyman i-try ko yung purolator or baldwin. :2thumbsup:
    Jan 2012
    #2796
    can someone post again the filtering efficiency of the
    LF551A - ?
    All i have is the one for the
    B2 - 98% * 30 microns, 50% * 12 microns, 22 grams contaminant holding capacity
    Apr 2009
    #2797
    Has anybody tried the sellers from sulit, saw one who supposedly sells Fleetguard, Baldwins and WIX and Napa, etc.?
    And what do you guys think of the magnets that you can cling to your oil filters? Supposedly these magnets keep the metal shavings (or whatever metal bits and pieces resulting from engine wear) from circulating... Any feedback on these?
    Jan 2012
    #2798
    Quote Originally Posted by decriz View Post
    i use hard disk drive magnets. they are ridiculously strong. they do attached the metal shavings.
    which seller are you referring to?
    Nov 2004
    #2799
    Neodymium Magnets, google mo how strong this magnet is...
    Dec 2007
    #2800
    I posted a big list a few months back but the LF551A is 98% 21 microns.
Remote bypass oil filtration
