Page 102 of 195 FirstFirst ... 252929899100101102103104105106112152 ... LastLast
Results 2,021 to 2,040 of 3899
    Quote Originally Posted by miked View Post
    ^^or sariling compilation mo yung data na yan.....makagawa nga rin ako ng local file ko. sa tagal kong nagresearch dito eh diko naisip yan. puros download lang ng pdf etc. hehehe
    I got it from their PDS sa net. Prices indicated are those I got from various suppliers here.
    Mas mataas nga TBN ng CF rated Gulf vs CI-rated but I guess this is not a concern kasi fleet service siya. Meaning hindi na pang-everyday cars so no need to apply for an API certification since its expensive. Tama na yung kaya nilang ipaliwanag sa mga fleet accounts nila na maganda talaga oil na ito. I think its Z & P will be really high since Cf rated oils at that time must have at least 1500ppm zinc. CF rated oil kasabayan niyan kasi is SG/SJ oils na pinakamatataas din additive packages.
    Dec 2009
    #2022
    Quote Originally Posted by tuazon7 View Post
    Got a response from Royal Purple Technical Manager for international markets. Will post it tomorrow, am on mobile now. Basically, what he is saying was that CJ-4 oils are okay for 500ppm diesel fuels (Euro II, which the Big 3 has) as the TBN is still within 20x of the sulfur content. That makes using Euro IV fuels (Unioil and Eastern) much much better. But since CI-4+ oils has a bit more of the anti-wear properties, it is still preferred to use this for additional engine protection. But for protecting both our engines and the environment, CJ-4 should be the choice...cheers
    Basta ako hands Down ako sa Royal purple lubricants.... they make one of the best you can possibly use...
    RP max gear gamit ko pati RP ATF fluid.... wala ako masabi sa performance... mahal nga siya pero superb performance,, yung ATF nila 1 year and 6 months na since nilagay sa automatic transmission( around 25k na tinakbo ) hangang ngayon walang change in color, smell, texture at napaka smooth shifting pa.... only downside is mahal... hahahaha...
    sa mga oil analysis sa BITOG forums abroad, 3 lang naman naglalaban in terms of oil analysis performance....
    Redline lubricants/ royal purple/ Mobil 1 synthetic line up...
    #2023
    currently using mobil tdt, before royal purple on our diesel truck. I feel the idling is better (less noise) and smoother with rp. mahal lang kasi.
    #2024
    SK company is the 3rd largest company in Korea, next to Samsung and Hyundai. They have teleco company too, and soon into a food business.
    now im confident in buying and using Zic oils hehe
    Dec 2007
    #2025
    Well as I posted before they are also the largest supplier of group III oils in the world. ConocoPhillips uses there group III oils exclusively.
    ChevronTexaco, Motiva and Petro-Canada also produce Group III in North America, primarily for internal consumption. ExxonMobil imports Group III that it produces elsewhere.
    Dec 2007
    #2026
    Dec 2007
    #2027
    Some oil change interval info. By automotive brands and a nice oil change calculator.
    Oil Change Intervals
    conversion for engine liters to cubic inches. Liters to Cubic Inches converter
    Stop Changing Your Oil - Edmunds.com
    How Often Should I Change My Oil? - Consumer Guide Automotive
    http://cartersauto.com/files/Oil_Drain_Interval.pdf
    Used the Kublin method and this is what I got. I assume this is in miles since that is the myth being busted.
    Virgin TBN - 8 is what i used
    Oil Capacity - 6 liters (should i use quarts?)
    Observed MPG - 26
    Engine C.I. - 173(2835cc)
    SAE Net HP - 123
    Change Oil At: 17553 miles
    haha, I definitely would not do that without proper oil analysis. But I think this is indeed indicative of the possible 15,000(24,135 kms) miles COI for a very good oil like Delo 400.
    Aug 2010
    #2030
    any comment on caltex delo 400 for diesel engine?
    Aug 2010
    #2031
    is zic oil available in manila?
    pls post the name of the store/s here.
    Oct 2011
    #2032
    Quote Originally Posted by trucker111 View Post
    maganda yan based sa mga post dito. it is rated API CI-4 Plus. saan mo nakita yan brad?
    #2033
    im not sure san pa meron sa manila, but i got mine from fellow tsikoter miko.
    Dec 2009
    #2034
    Pm nyo ako kung interested kayo sa ZIC oils, especially ZIC A, para isang orderan lang...hehehe...
    Aug 2010
    #2035
    Quote Originally Posted by miko101130 View Post
    can you post the price here? tnx
    Ito na ginagamit ko ngayon. Maganda feedback dyan sa kahit na anong forum dito man or sa Pinas. Nice additive package kasi while not pricey.
    #2037
    insides of a bosch OM 084 oil filter
    it looks very similar to the oem mitsu oil filter posted a while back...
    *dvldoc
    can this go 10,000kms same with the oem mitsu oil filter?
    #2038
    ^changed filter * ~4800kms, change oil * ~13000kms.
    used royal purple oil.
    Dec 2007
    #2039
    Looks very good, I wonder what the efficiency rating is on them.
    ^ Using Delo 400, can I use the oil * 10,000kms while changing bosch oil filter every 5,000kms? Or should I changed oil filter * 6,000kms and increase oil change interval to 12,000kms?
Remote bypass oil filtration
