Page 97 of 195 FirstFirst ... 478793949596979899100101107147 ... LastLast
Results 1,921 to 1,940 of 3899
    Sep 2010
    #1921
    ^ have you tried Volmax already?
    haven't tried yet. aside from kailangan sadyain ang lugar, i believe everyone is still waiting for the latest shipment to arrive.
    it seems they've wised up (volmax), increasing the SRP of the filters due to insistent forum demands.
    also, majority here have mitsubishi, toyota & honda rides.
    the B104 is for my 4JA1, cross for the (BIG size) VIC C-503 oil filter.
    #1922
    tumaas napo ba price ng bd28? hehe magkano napo?
    Dec 2007
    #1923
    Quote Originally Posted by SpeedDzel View Post
    You can also go with the B1446
    Sep 2010
    #1924
    Hi dvldoc!
    the Baldwin B1446 is the cross for the Vic C-512 (small size), used by crosswinds with M/T and non Turbo models.
    my 2003 XUV is a 4JA1(NA, L) variant with A/T, Turbocharger that comes with the BIG size filter.
    if ever, will the small type filter not affect or hinder performance of this kind of engine set up/configuration?
    This is what i've gathered so far.. My OEM# 8-94167-399-0
    crosses with the ff;
    ITSUMO 8-94167-399-0
    JSAKURA C-503
    Baldwin B109
    Fleetgrd LF3433
    Donaldson P905002
    MANN W92180
    WIX 51386
    BOSCH OM 037 (aka OF 503)
    FRAM PH4731
    VIC C-503
    whilst the small type filter (not designated for my ride)
    OEM# 8-94430-983-0
    Baldwin B1446
    Fleetgrd LF3528
    Fleetgrd LF3786
    Wix 51523?
    Donaldsn P502039
    Vic C-512
    Sep 2010
    #1925
    Quote Originally Posted by AC View Post
    mukang may balak na ata sila magtaas based on sir troyadam's post a few pages back...
    Quote Originally Posted by troyadam View Post
    They might increase the price, When their shipment comes sabi ng volmax. Lalo na in demand na ang filter. I try to call the fleetguard sa new manila baka may LF3564 the same as Bd28.
    Sep 2010
    #1926
    Sir! any significant changes on your engine after shifting to Mobil Delvac MX? Does it accelarates faster or engine becomes more quiet?
    Sir Retz, kilala talaga ang 4JA1 or isuzu engines na malayo ka pa, the gate is opened by the time you reach it. hehehe
    beep beep! pasensya na po sa mga kapatid na naka isuzu... hehehe
    i don't think anything can be done anymore to lower the dB noise of isuzus. that's why many recommend to set up a GOOOD & LOOOUUUD sound system instead.
    :laughbounce:
    seriously, i can't tell any major difference at the moment except for tumaas ang idling ko. probably as i said lumuwag luwag ang hinga ng makina
    she's still under observation 'cause i replaced my water pump due to a loose bearing na after our office staff borrowed my ride and went to La Union and Baguio. They returned it to me and i noticed my clutch fan was wobbling wildly! and the engine was vibrating abnormally. wala naman akong magawa, hindi ko naman pwede sermonan yung mga humiram. that's life..
    Dec 2007
    #1927
    Hi dvldoc!
    JSAKURA C-503
    Baldwin B109
    Fleetgrd LF3433
    Donaldson P905002
    MANN W92180
    WIX 51386
    FRAM PH4731
    VIC C-503
    OEM# 8-94430-983-0
    Baldwin B1446
    Fleetgrd LF3528
    Fleetgrd LF3786
    Wix 51523?
    Donaldsn P502039
    Vic C-512
    Ever hear the phrase size does not matter, The Baldwin B1446 has 3 times the dirt holding capacity over the Vic, They also will have more pleats and 3 times the efficiency rating. So going with the larger filter will make little difference in your oil change intervals if your not going over 12000klm per oil change.
    The B106 holds 20.81 grams
    The B1446 holds 18.04 grams (has no anti drainback valve) which is not needed if a filter is not mounted upside down.
    The flow rating are also close the smaller has 25gpm while the larger has 22gpm so the smaller one actually flows better.
    You can stray from OEM recommendations quite a bit, If you do a little back reading you'll see how I explain this. Both these filters will work on your vehicle, having a turbo makes no difference, especially one that only makes 4hp over the stock engine, People keep the same filters when adding a turbo to their current engine.
    As long as the sizes is close to the same, the bypass valve is close to the same, in this case they are identical at 20psi you are good to go.
    Don't limit yourself with options by only going with the OEM number.
    Sep 2010
    #1928
    Thanks dvldoc, that is very assuring to know.
    yeah, hear that adage often. hehehe
    it'll all boil down to which will be available here in metro manila. kinda frustrating though.
    Sep 2010
    #1929
    guys, this is i guess off topic but i have a theory regarding the production of filters for the asian market versus the american / european market.
    as we all know, whoever has not yet put up a production plant (or contractor) in china is being left in the game of production.
    the driving purpose is supposedly the lower cost. i estimate 10 chinese workers would cost the same as 3 non-chinese asian workers (filipino, indian, etc) versus 1 american/european worker. are you following me?
    with that, to drive costs further down, i suspect that the big producers (american & european) have approved a different (LOoOWER) standard for the asian market / consumers. hence the proliferation of what we know as counterfeit, knock offs or better yet imitations.
    we know that singapore is a distribution hub and not a production source. i guess they are in charge of sourcing out production in china, malaysia, thailand etc. wherein with their quest for cost effectiveness for the asian theatre, they have lowered the standards compared to the american & european side.
    this would explain the lack of enthusiasm from the headquarters state side in pursuing the complaints lodged to them.
    what do you guys think?
    :detective:
    #1930
    :detective:
    Sounds logical.
    As the song says..."leave them with 3rd world devices".
    #1931
    sa alam ko po mas mataas na ang minimum sa china kesa saatin..
    mura lang po yata kuryente nila and efficient po mga system nila
    #1932
    They also have problem wilth the supply of electricity. Their plant have sched shutdown on a weekly basis especially on summer.
    Quote Originally Posted by doy View Post
    Looks like I'll have to search for a Baldwin dealer here or in Davao. Fleetguard for oil and Baldwin for fuel. OEM fuel filter here cost Php 2,500+ which almost 3 times the price of Fleetguard FF5160.
    Asked WL Trading in Davao last Monday, they don't have LF3564 in their inventory.
    Bibili na sana ako if meron eh.
    #1934
    Sir, check ninyo din kung golden pa din ang oil color after 500kms lalo na with Baldwin BD28. Still got a golden oil color after 500kms with Fleetguard LF3564. Panalo talaga ang price at performance ng ZIC UP.
    doy - sir, can you share your good experience with Zip UP?
    Apr 2012
    #1935
    Hi Sir Doc,
    Maybe you can supply us some filters. I think a lot of member would buy from you. Just making some suggestion.
    Oct 2004
    #1936
    I noticed the engine response to be smooth even at 4,500kms with ZIC UP. This was with OEM oil filter only. I'm hoping for an even smoother response upto 5,000+ kms with Fleetguard LF3564. ZIC SD5000 (15w-40 multi-grade with CF-4 rating; Php 170/liter) was already rought at 4,000kms with OEM oil filter.
    Dec 2007
    #1937
    I plan on doing it as a hobby to keep busy, I retire from the US Navy after 20 years next month. I'll be in the Philippines 60% of the time.
    Oct 2004
    #1938
    The provincial dealers usually do not stock LF3564 since it's not a fast moving item. Order basis lang with downpayment. The dealer here in CDO took 4 days to get my order. The salesman couldn't even believe that I will be using the filter for a Strada. They usually sell the filters for heavy equipment & big trucks. Hehe.
    Dec 2007
    #1939
    Tell them to read this thread so they can see the demand for it.
    #1940
    the only bad thing with dealers/distributors knowing that there is a market for their items is that they will jack the price as soon as they can. just like what the previous poster said when Volmax commented that they might increase the price. i hope they dont since the forex rate is already getting better at 42.50 = 1. i dont see any reason why they should increase price since it will be cheaper for them to import it..
Remote bypass oil filtration
