actually checked it right after oil change. but it was a bit dark agad. probably cause the previous oil i use was really really dark when we drained it. but its ok since i know im using a good oil + filter combo. will drain the oil after probably 5-6000km and have it analyzed.
Miko, can you PM me the contact of the company with used oil analysis? thanks!
Hi Sir Doc,
Maybe you can supply us some filters. I think a lot of member would buy from you. Just making some suggestion.
I noticed the engine response to be smooth even at 4,500kms with ZIC UP. This was with OEM oil filter only. I'm hoping for an even smoother response upto 5,000+ kms with Fleetguard LF3564. ZIC SD5000 (15w-40 multi-grade with CF-4 rating; Php 170/liter) was already rought at 4,000kms with OEM oil filter.
