Page 96 of 195 FirstFirst ... 46869293949596979899100106146 ... LastLast
Results 1,901 to 1,920 of 3899
    #1901
    Quote Originally Posted by troyadam View Post
    How much is volmax selling? went their yesterday still no stock. How much then is your filter cost from your computation? tia
    Volmax-p765 vs p880(still in sanfo). If i am going to have them shipped here, it's going to be p1100, so no choice but to have a relative bring them here maybe by 2s or 3s (if they are planning to travel for vacation).
    Mar 2012
    #1902
    meron din bang available or compatible na caterpillar oil filter for car engines?
    Wala, pareho man ang threads, malalaki ang mga canister sizes kaya hindi puede.
    #1903
    Quote Originally Posted by zix888 View Post
    zix, where did you find the baldwin in US? i'll try to order a few and have it shipped here c/o balikbayan box. makikisabay lang sa dad ng gf ko para free muna shipping hehe kindly PM it to me
    Quote Originally Posted by miko101130 View Post
    Bro, the oil that you are seeing on the turbocharger outlet side is normal... that is if the PCV recirculation system is till present...
    the PCV system vents the blowby gas towards the intake side of the turbo compressor, the vapors will condense and form a liquid oil on the discharge side of the turbo.. thats normal....
    if you want that oil to lessen, you have to put catch can.. or if you want it to completely disappear you have to disconnect the PCV hose and let it vent the vapors into the atmosphere...
    miko, was able to find the culprit. it was a loose clamp on the turbo. tightened it already.
    had my oil change today on my 4m40 to Zic UP 10w40. coupled with Baldwin BD28. i got the last piece from Volmax early march.
    Dec 2009
    #1904
    balitaan mo ako sa performance nang ZIC UP CB... hehe....
    Apr 2012
    #1905
    They might increase the price, When their shipment comes sabi ng volmax. Lalo na in demand na ang filter. I try to call the fleetguard sa new manila baka may LF3564 the same as Bd28.
    Dec 2007
    #1906
    Quote Originally Posted by miked View Post
    and the OEM fuel filter is standard flow, right?? if it is, maybe i'll go OEM so as not to change also the priming pump.
    Same flow or it would not work, it's because it's a filter and fuel water separator.
    Nov 2011
    #1907
    still could not get hold of a Baldwin for my Estima.
    tulong po. para po sa 3C engine. cross po sya ng Vic C-112.
    Baldwin: BD7029
    Fleetguard: LF3849
    Wix: 51368
    PM nyo po ako if meron kayo makukuha. TIA.
    OT:
    thanks miko for the mobil oil delivered last time. cencia di ako nagtagal kase un P.Steering ko may tagas that night. Nag-loose lang pala as ilalim. Ok na sya ngayon. Next month bili ulit ako ng oil. hehe.
    #1908
    miko, first impression of the oil, mabaho. haha! the smell is unpleasant. but after using it for 350km straight yesterday, the engine seems to idle very smoothly. probably because of the viscosity. 10w40 vs 15w40(old oil). will try to observe pa in a couple of days.
    Dec 2009
    #1909
    ganyan din dati nung ginamit ko bardahl na fully synthetic, meh something na amoy... parang pungent yung smell...
    Oct 2004
    #1910
    Sir, check ninyo din kung golden pa din ang oil color after 500kms lalo na with Baldwin BD28. Still got a golden oil color after 500kms with Fleetguard LF3564. Panalo talaga ang price at performance ng ZIC UP.
    #1911
    Quote Originally Posted by doy View Post
    actually checked it right after oil change. but it was a bit dark agad. probably cause the previous oil i use was really really dark when we drained it. but its ok since i know im using a good oil + filter combo. will drain the oil after probably 5-6000km and have it analyzed.
    Miko, can you PM me the contact of the company with used oil analysis? thanks!
    Sep 2010
    #1912
    :hieveryone:
    Good Day to all!
    i discovered this ttttthrrrread and have rrrread thru it for moooore than a WEEK... :sweat: :sweat: :sweat:
    and this thread is looong hehe :arms:
    but the looong read thru was very much worth it!
    #1913
    Quote Originally Posted by SpeedDzel View Post
    :hieveryone:
    Good Day to all!
    Kudos to you for taking the time to read it. Dami mo talaga matututunan through the backread.
    Sep 2010
    #1914
    thank you sir VINJ! i feel like my brain got toasted.. overheated trying to absorb everything :boom: hehehe
    i did an Oil & Oil Filter Change last 18April, settled for a...
    Bosch OM 037 oil filter to replace a Vic C-503
    and
    Mobil Delvac MX 15W-40 CI-4 replacing Castrol CRBTurbo
    purchased at Bionicwheels in Aurora, Cubao. (listed as an authorized Bosch Repair Center).
    1pc Bosch OM 037 . . PhP 280
    1L Mobil Delvac MX . .PhP 250
    5L Mobil Delvac MX . .PhP 1,250
    they also have
    Top1 SDO . . . . . . . .PhP 320? (if i recall right)
    LiquiMoly Lubes etc
    will upload & share photos of the items.
    will also break open the used VIC filter...
    coming soon!
    #1915
    and
    they also have
    LiquiMoly Lubes etc
    coming soon!
    their mobil delvac mx is a little expensive. i think its only around 200 sa mga DIY stores. as for Top1 SDO, price in auto supplies is around 260-290pesos.
    Oct 2011
    #1916
    and
    they also have
    LiquiMoly Lubes etc
    coming soon!
    Sir! any significant changes on your engine after shifting to Mobil Delvac MX? Does it accelarates faster or engine becomes more quiet?
    Sep 2010
    #1917
    that's correct, mahal nga si Bionicwheels sir CB but i was pressed for time na. sila lang alam ko na may Bosch na malapit. as i Had to travel up Up UP north right after the OCI.
    initial observation; i think lumuwag / nakahinga ung makina. medyo tumaas ang idling (engine). :detective:
    #1918
    what we do for our fleet is to buy in bulk/wholesale so you will get it at a lower price. before we used to buy Top1 SDO for our diesel engines. now trying Zic UP. Ok naman Top1, hindi mausok as compared to Shell Rimula. For our gas fed engines, we're using Zic A naman.
    Sep 2010
    #1919
    roger that sir. ZIC has indeed caught my attention. I'm eyeing it for the next OCI.
    also, very much would like to use a Baldwin. But it seems the B104 is very HARD to find or source
    #1920
    ^ have you tried Volmax already?
Remote bypass oil filtration
