Results 1 to 20 of 3899
    Quote Originally Posted by zix888 View Post
    Volmax-p765 vs p880(still in sanfo). If i am going to have them shipped here, it's going to be p1100, so no choice but to have a relative bring them here maybe by 2s or 3s (if they are planning to travel for vacation).
    zix, where did you find the baldwin in US? i'll try to order a few and have it shipped here c/o balikbayan box. makikisabay lang sa dad ng gf ko para free muna shipping hehe kindly PM it to me
    Quote Originally Posted by miko101130 View Post
    Bro, the oil that you are seeing on the turbocharger outlet side is normal... that is if the PCV recirculation system is till present...
    the PCV system vents the blowby gas towards the intake side of the turbo compressor, the vapors will condense and form a liquid oil on the discharge side of the turbo.. thats normal....
    if you want that oil to lessen, you have to put catch can.. or if you want it to completely disappear you have to disconnect the PCV hose and let it vent the vapors into the atmosphere...
    miko, was able to find the culprit. it was a loose clamp on the turbo. tightened it already.
    had my oil change today on my 4m40 to Zic UP 10w40. coupled with Baldwin BD28. i got the last piece from Volmax early march.
    Dec 2009
    balitaan mo ako sa performance nang ZIC UP CB... hehe....
    miko, first impression of the oil, mabaho. haha! the smell is unpleasant. but after using it for 350km straight yesterday, the engine seems to idle very smoothly. probably because of the viscosity. 10w40 vs 15w40(old oil). will try to observe pa in a couple of days.
    Oct 2004
    Sir, check ninyo din kung golden pa din ang oil color after 500kms lalo na with Baldwin BD28. Still got a golden oil color after 500kms with Fleetguard LF3564. Panalo talaga ang price at performance ng ZIC UP.
    Quote Originally Posted by doy View Post
    actually checked it right after oil change. but it was a bit dark agad. probably cause the previous oil i use was really really dark when we drained it. but its ok since i know im using a good oil + filter combo. will drain the oil after probably 5-6000km and have it analyzed.
    Miko, can you PM me the contact of the company with used oil analysis? thanks!
    doy - sir, can you share your good experience with Zip UP?
    Apr 2012
    Hi Sir Doc,
    Maybe you can supply us some filters. I think a lot of member would buy from you. Just making some suggestion.
    Oct 2004
    I noticed the engine response to be smooth even at 4,500kms with ZIC UP. This was with OEM oil filter only. I'm hoping for an even smoother response upto 5,000+ kms with Fleetguard LF3564. ZIC SD5000 (15w-40 multi-grade with CF-4 rating; Php 170/liter) was already rought at 4,000kms with OEM oil filter.
Remote bypass oil filtration
