dvldoc, could the use of wrong oil cause a turbo charger to "sweat" oil? my 4m40 has a small oil leak at the compressor outlet of the turbo charger. im not sure if the leak occurred during the rebuild of my motor (failure to clean the leak from the repair) or after.
current oil used is Shell Rimula R1 SAE40 API-CD. ran 3,000km.
Bro, the oil that you are seeing on the turbocharger outlet side is normal... that is if the PCV recirculation system is till present...
the PCV system vents the blowby gas towards the intake side of the turbo compressor, the vapors will condense and form a liquid oil on the discharge side of the turbo.. thats normal....
if you want that oil to lessen, you have to put catch can.. or if you want it to completely disappear you have to disconnect the PCV hose and let it vent the vapors into the atmosphere...
