Page 93 of 195 FirstFirst ... 4383899091929394959697103143193 ... LastLast
Results 1,841 to 1,860 of 3899
    #1841
    I know this has been discussed so many times before in this thread but I'll ask again. The main reason why some people change oil regularly at a short interval is to avoid the formation of sludge inside the engine. Having said that, is it bad oil filtering that causes the formation of those sludges? or is it the oil itself which at some point will degrade and sludge the engine? sa oil ba ito or sa filter?
    answer of dvldoc few pages back.
    dvldoc, speaking of sludge, is it safe to assume that sludge is from use of low quality oil + low quality filter?
    Folks we have our self a winner, You got it crazy boy, it's the number on reason for sludge, second is other contaminates like coolant. Some engines are just sluge monsters due to a bad design, Toyota's 1997 to 2002 for example.
    If you use a low detergent automotive oil then you can expect to have a sludgy engine. If you have a coolant system leak expect the same. That's why it's always best to know what's in your oil, It's good to pull your valve cover from time to time just to check if everthing's good to go.
    Oct 2011
    #1842
    Thank you sir cb and dvdldoc. Could you recommend a good mineral based oil brand? some of the brands I'm familiar with are Toyota OEM mineral oil, Castrol, Repsol. Good brands like Royal Purple, Mobil 1, Motul, Top 1 are mostly of synthetic type.
    #1843
    Try Zic brand oils. Its recommend by dvldoc as well. Group3 synthetic. so basically highly refined mineral oil siya. price is not so expensive naman.
    Dec 2009
    #1844
    pa OT, crazy boy, are you by any chance a member din ng pajero club.. PCP?
    #1845
    Quote Originally Posted by miko101130 View Post
    lurker lang miko hehe pati sa PPAC. why?
    BTT: Retz, try to contact miko, he sells Zic brand oil.
    Apr 2012
    #1846
    They're near the 5th Ave. LRT station along Rizal Ave. Some word of caution with Pacer though. We bought a couple of Fleetguard filters from them a few months back and per checkings with dvldoc and cross-referencing the pics of what we got with what can be seen online, there's suspicion it may be fake. We're trying it now with a 5000km OCI and will open it up right after to confirm whether the filter is good or not.
    Ito ba yung dating Caterpillar? Before i went there to buy some parts for caterpillar genset. Mismo sa station sila naka pwesto. PACER na pala sila?
    maybe i will buy the filter first then have it fit it with the base. Just like to know if i use the DB28 for the stocks oil filter then what filter should i use for the bypass filter? Tia
    Oct 2011
    #1847
    okay, thanks sir cb. will consider Zic oil brand. I assume it is semi-synthetic based on your description.
    Dec 2007
    #1848
    ZIC has semi, full and strait mineral oil. I think with it's price I would go with their full synthetic.
    Dec 2009
    #1849
    kaya pala.. kasi same handle din yung name mu dun.. hahaha... attend ka minsan pag nag meet sila... twice pa lang ako naka attend eh...
    Oct 2011
    #1850
    okay, do update us bro. how about baldwin filters in volmax? guaranteed genuine ba ito? nakapanghihinayang kasi kung fake pala nabili mo.
    Oct 2011
    #1851
    API CJ-4 diesel oil rating are used in diesel fuels ranging in sulphur content up to 500ppm. However, use of these oils with greater than 15ppm sulfur fuel may impact exhaust after treatment system durability and/or oil drain intervals.
    What is the meaning of the bold sentence above? Low sulfur content are those under Euro V or IV standard fuels that are imported.
    #1852
    Hi Sir any Idea kung saan pwede makabili nito? I've Search the net for this brand and found at that they have variety of Oil, Magkano po kaya ang price range nito?
    #1853
    Is BT223 can be used for Toyota Fortuner w/ 2.5 engine?
    #1854
    Quote Originally Posted by batosai View Post
    try to PM miko101130. baka may stock pa siya.
    yes sir,
    Oct 2011
    #1855
    pwede sa 2kd-ftv engine.
    Mar 2012
    #1856
    Quote Originally Posted by troyadam View Post
    The Caterpillar dealer is Monark. Monark is the one below the LRT station. Pacer is
    on the other side of Rizal Avenue, diagonally across Monark.
    #1857
    Hi sir cray boy, Hi sir Retz, thanks.. I'll contact sir Miko for details of Zic oil.. So if BT223 will fit the fortuner same lng pala sila ng filter that I'm using with my 1995 toyota corolla 1.6 engine
    Dec 2009
    #1858
    batosai, anu ba auto mo? do you prefer fully synthetic or semi?
    sir retz, all baldwin from volmax are legit... so far wala pa naman dubious product from them....
    Jan 2008
    #1859
    IIRC:
    Euro 2 = 500ppm
    Euro 3 = 350?300? (SeaOil diesel)
    Euro 4 = 50ppm
    Mobil 1 TDT lang yata ang Cj-4 rating oil na nakita ko at na mention sa thread na to.
    Back read a lil bit, Dvldov has link re: Cj-4 vs Ci-4(+). Cj-4 isnt good for the Cat-Con afaik.
    Dec 2009
    #1860
    if i'll choose between Cj-4 and CI-4... i'll take CI-4 anytime of the day...
Remote bypass oil filtration
