Thank you sir cb and dvdldoc. Could you recommend a good mineral based oil brand? some of the brands I'm familiar with are Toyota OEM mineral oil, Castrol, Repsol. Good brands like Royal Purple, Mobil 1, Motul, Top 1 are mostly of synthetic type.
pa OT, crazy boy, are you by any chance a member din ng pajero club.. PCP?
Ito ba yung dating Caterpillar? Before i went there to buy some parts for caterpillar genset. Mismo sa station sila naka pwesto. PACER na pala sila?
maybe i will buy the filter first then have it fit it with the base. Just like to know if i use the DB28 for the stocks oil filter then what filter should i use for the bypass filter? Tia
ZIC has semi, full and strait mineral oil. I think with it's price I would go with their full synthetic.
API CJ-4 diesel oil rating are used in diesel fuels ranging in sulphur content up to 500ppm. However, use of these oils with greater than 15ppm sulfur fuel may impact exhaust after treatment system durability and/or oil drain intervals.
What is the meaning of the bold sentence above? Low sulfur content are those under Euro V or IV standard fuels that are imported.
Hi sir cray boy, Hi sir Retz, thanks.. I'll contact sir Miko for details of Zic oil.. So if BT223 will fit the fortuner same lng pala sila ng filter that I'm using with my 1995 toyota corolla 1.6 engine![]()
batosai, anu ba auto mo? do you prefer fully synthetic or semi?
sir retz, all baldwin from volmax are legit... so far wala pa naman dubious product from them....
if i'll choose between Cj-4 and CI-4... i'll take CI-4 anytime of the day...
