Results 1,331 to 1,340 of 3899
March 2nd, 2012 02:06 PM #1331
doc, how about salvaging the filtration system of a willys jeep engine....from the looks of it, it looks like a bypass filter. if i'm not mistaken the size of the hole on the discharge is 1/16 of an inch. search on the baldwin site gave me the P40 pail type filter.
March 2nd, 2012 02:08 PM #1332
a quick search on the net with regards to valvoline turbo 15W40 CF4 gave me an average of 8-10 TBN. yes it's cheap at P200/liter but i think i'd better switch back to delo gold which is stouter.
March 2nd, 2012 02:27 PM #1333
I have no ideal on that on, 1-16th is pretty much a cummins engine size.
This is the adapter I use to convert the kits 3/4 16" thead to a 1-16" thread, You just screw it on.
Now here's the deal you can just get this adapter above if you already have a 3/4 16 thread and have 8" of clearance and put a LF9028 or BD7317 directly on your vehicle. Would work on things like the TD42, TD27, Ford Everest ect ect. Your not going to fit it on most cars due to the space requirements without getting the full kit.
A competent machine shop could make this adapter for almost any size filter thread. It allows you to use a much larger and better filter.
March 2nd, 2012 03:03 PM #1334
dvldoc,
is it important to follow the manufacturer's recommendation of viscosity rating? in the manual of the innova and vios, the recommended rating is 15w40 and 20w50 for the Philippine climate.
im thinking of using 10w40.
thanks!
March 2nd, 2012 03:51 PM #1335
March 2nd, 2012 04:31 PM #1336
hi doc, been reading your thread sometimes,is it OK NOT to change my oil filter if i used trekker oil for only 1200kms? cause i wanna try the delo gold multigrade...
btw, i used vic filter ( sorry, due to unavailability of best filters in our province, vic is the only available filter here ).....
March 2nd, 2012 05:04 PM #1337
Bro pa-order ka na online ng bosch oil filter. Meron dito.
Pinoy Superstore
Fasten your seatbelt! Or else...Driven To Thrill!
March 2nd, 2012 05:16 PM #1338
*Ry_Tower
pareho lang ba yan sila ng baldwin o fleetguard sir? salamat nga pala sa link..
March 2nd, 2012 05:59 PM #1339
Better ang baldwin, purolator or fleetguard (as long as orig as mentioned here). Mas sureball kung fleetguard na lang sa volmax bibilhin mo if ever. Thrice better than Vic kasi mga yan.
But Bosch is really good vs Vic. 2,800kms na odo o sa filter na yan for 3 months at yung oil wala ako ma-feel na sandy bits hindi gaya ng Vic dati na aglit lang may sandy feeling na yung oil. Alam mong may mga abrasive materials already circulating the engine and other parts .Fasten your seatbelt! Or else...Driven To Thrill!
March 2nd, 2012 06:43 PM #1340
see you tom din sir crazy_boy... ill give you a free material on lubricants so you can really decide whats best for you.. hehe..
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
