Results 1,221 to 1,230 of 3899
February 17th, 2012 11:27 AM #1221
Delo silver is a good oil, can definetly run longer than 3kms, It does have a TBN of 9.6
https://cglapps.chevron.com/msdspds/...&docFormat=PDF
http://www.msdsonline.com.au/msds/ms...=&uselogo=TRUE
Product sheet https://cglapps.chevron.com/msdspds/...&docFormat=PDF
You can find all Delo msds and product sheets here https://cglapps.chevron.com/msdspds/...y=®ion=APAC
Delo siver can be considered semi synthetic as it has group III oil blended in with it. and it has greater than 1000ppm zinc so that's a good thing. If it's anything like the Delo 400 it probably has a good dose of moly and boron in it as well. Delo oils are for commercial vehicle use so they are stout.l
February 19th, 2012 05:30 AM #1223
February 19th, 2012 03:31 PM #1224
Dvldoc - if thats the case, then I guess I should stop using Top1 and switch to Delo Gold/Silver. currently im using Shell Rimula R1 to rinse my engine.
Will change it after 3months of use.
this is the tech spec of the Top1 Synthetic Diesel Oil
Product Designation SDO
SAE Grade 15W-40
API Gravity 29.1
Viscosity
SUS * 100º F 503
SUS * 210º F 76
cSt * 40°C 116
cSt * 100°C 15.6
Viscosity Index 140
Flash Point, C° (F°) 238 (460)
Pour Point, C° (F°) -39 (-38)
Total Base Number 11.8
Ash, Sulfated, wt% 1.37
Phosphorus, wt % 0.127
Zinc, wt % 0.137
Foam Test Pass
Paj4x4 - sir, are you using Delo Sport or just Delo Gold multigrade?Last edited by crazy_boy; February 19th, 2012 at 04:27 PM.
February 20th, 2012 01:56 AM #1225
Those two oils are so close in performance it's going to have to be a choice based on price, anything over 1200ppm zinc is pretty good protection. they both have high calcium which is for cleaning your engine. Delo is more tailored for commercial vehicle use. I know here in the states it's now cheaper than Mobil Delvac 1300 super both great oils.
But the Moly level and boron do give Delo a bit of a friction protection advantage, Top one has a moly additive. I would not use this in a newer gas engine since the zinc level is around 1500ppm but for a older diesel you would be hard pressed to find a better oil that can easily run 8000kms to 10000kms with a good filter for the money.
Top 1 is one of the best bangs for the buck for most gas engines. Again it boils down to price, your not going to get significantly more wear from using top 1 over Delo on a passenger vehicle. Delo is really for big trucks and mid sized commercial vehicles. Which makes it even better for a daily driver POV.
Go on price and availability.
February 20th, 2012 07:45 AM #1226
February 20th, 2012 09:22 AM #1227
I'd go with the Delo especially if your not going past 8000kms. It's all about what's the cheapest and easily available.
February 20th, 2012 10:08 AM #1228
February 20th, 2012 10:35 AM #1229
Additives and API ratings are more important than mineral vs synthetic.
Your dyno oil has the additive packages like those in Delo to keep pace with synthetic oils, Not all dyno oils do though. For example this is your typical additive packages. Additives: Additives are the different chemicals within the motor oils, which help oil and the engine to function properly. Additives usually include:
Anti-wear agents
Anti-foam agents
Anti-rust and corrosion agents
Oxidation Inhibitors
Extreme Pressure Additives
Viscosity Index Improver
Friction Modifiers
Pour Point Depressants
Here's the deal unless you have a high performance high horsepower engine you will see little difference. I would rather use a mineral oil with the Delo add package over SN RATED mobil 1 oil with only 800ppm zinc vs delo's 1500ppm.
And engines like old school diesels will do much better with the highest additive package possible. If your not doing extended drain intervals there really is no advantage.
Good little article that help explains it. Synthetic Vs. Mineral Motor Oil - Engine, Oil Tech - Hot Rod Magazine
February 20th, 2012 10:54 AM #1230
Mga masters, just want to ask if you have any idea about this oil company?
http://media.jcprimo.com/permalink/A...0Catalogue.pdf
I'm talking specifically Primo Grand Racing 4T oil.Fasten your seatbelt! Or else...Driven To Thrill!
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
