The 1FZ-FE will take a Baldwin B2 filter. And your 100 series fits a Baldwin B228 filter but if you have a extra 3 inches of space i would use the long version which is the B178 it will give you longer filter life with the added media surface. You'll just have to check to see if you can fit that with nothing touching the filter and still be able to access it with a filter wrench to remove or replace.
Bosch in the states is different from there so the numbers will probably be different but it would be a 72161 for the 100 series and for your 80 series would be a 3510.
Your going to have to stick with OEM or other local brands for the fuel filters, if you want a Baldwin. Wix does have some though, the WIX 33526 for the 100 series and WIX 33563 for your 80 series. But frankly Toyota makes good fuel filters. If your in the Metro Manila area there is a WIX dealer it's posted on this thread but I don't know what page.
Thanks dvldoc.
I checked the cross reference sites you posted in this thread. Also checked sites of Auto Parts stores stateside – Kragen, Pep Boys, and Autozone. These are the part numbers I came up with for my LC 100 (2UZ-FE) and LC 80 (1FZ-FE). Appreciate if you can confirm if these are the correct ones.
There are no stocks of Bosch and Baldwin oil filters for these rigs in Warren and Volmax. Superior Motors has the Wix 51348 and 51515 in stock – they are only priced at P240 and P199 respectively – at these prices I’m having doubts if these are genuine Wix filters.
Have an upcoming trip to the US so will probably get the filters for these two rigs over there.
LC 100 (2UZ-FE engine)
Wix
- part # 51348
Bosch
- part # 3330 or 72161
Baldwin
- part # B159 or BT223
Purolator
- part # L10241 or L22821
LC 80 (1FZ-FE engine)
Wix
- part # 51515
Bosch
- part # 3330 or 3500
Baldwin
- part # B2
Purolator
- part # L30001 or PL10241
* Could not get part numbers for Fleetguard filters for these engines.
By the way I’ve shifted to Bosch oil filter for my wife’s Pajero Gen 2.5 (4m40TDIC). Will try out Baldwin (BD28 or BD7028) from Volmax in my next oil change. I currently change the oil at 4,000km intervals and oil used is Caltex Delo 15w-40 mineral oil. If I use the Baldwin can I extend the oil change interval?
Thanks once again dvldoc.
