Page 103 of 390 FirstFirst ... 3539399100101102103104105106107113153203 ... LastLast
Results 1,021 to 1,030 of 3899
    #1021
    Just got my mobil 1 turbo diesel truck, now 450 *trading post , 2nd floor of cash and carry
    #1022
    Quote Originally Posted by zix888 View Post
    P10 price hike ah. hehe
    Jun 2005
    #1023
    hey doc, do you know the technical specs of mobil1000? it readily available is it a good dino juice?
    #1024
    Yup you are correct! I saw some mobil 1 15w-50 fully syn, is it also good? In case these tdt ran out?
    Dec 2007
    #1025
    Quote Originally Posted by sirkosero View Post
    It's no better and no worse than a oil of the same API rating that is group II oil.
    Mobil Super 1000
    Here is a good listing I found which breaks down oils brands with what group of oil they are ie. Group II, III, IV or V.
    Auto-Rx (Philippines) | About Oil
    Dec 2007
    #1026
    It's no better and no worse than a Group II oil with the same API rating. Not a big fan of Group II as it has a lower TBN and will have to be replaced sooner. You would be better off with a group III oil.
    Here's a good listing of some oils there with the groups types.
    #1027
    Mobil 1 15W-50 Advanced Full Synthetic Motor Oil
    API rated only as CF plus its rated SN which is not ideal for diesel per se, maybe better off using Mobil Delvac MX 15w40 or Mobil Delvac 1 5w40 instead if meron sila sa Trading post.
    MOBIL DELVAC 1 5W-40
    Viscosity, ASTM D 445
    cSt * 40șC 102
    cSt * 100șC 14.8
    Viscosity Index, ASTM D 2270 151
    Sulfated Ash, wt%, ASTM D 874 1.35
    Total Base #, mg KOH/g, ASTM D 2896 12
    Pour Point, șC, ASTM D 97 -45
    Flash Point, șC, ASTM D 92 226
    Density * 15șC kg/l, ASTM D 4052 0.854
    Moreso from 2 threads i've read they stopped making this already.
    mobil 1 synthetic 15w 50 silver cap auto oil - Bob Is The Oil Guy
    May 2009
    #1028
    ^in contrary, API CF is rated for use with diesel fuels having greater than 0.5% ppm sulfur. higher than CF are those oils for use with fuels lesser than 0.5% ppm sulfur. not that i'm against those high ratings with regards to API ratings (actually, i've been a user of CI-4 delo gold multigrade). what i'm saying is if you use API rated oils higher than CF, you have to change your oil more often than when you are using CF. by the way, i dropped my pan for the first time and i'm really surprised with the internal condition. no sticky gunk on the pan as well as on the sides of the block. well, thanks to delo of course. found only bits of silicone sealant at the pump screen and on the pan as well. i filled her up again with valvoline CF-4 15w-40.
    #1029
    cSt * 40șC 102
    cSt * 100șC 14.8
    Alright thanks for the info sir Ry_Tower
    Jun 2009
    #1030
    Sir bought mine at Shopper's Delight, 2nd floor also at Cash&Carry, 440 per quart and yes madami sila stocks ng engine oils there like Top1 and different grades of Mobil 1's, all made in USA
Remote bypass oil filtration
