Funny you mention that, I just ordered a bunch of LF9028 filters which is the Venturi combo filter. The Balwin equivalent is Baldwin BD7317. Decided to replace one of my Full flow filters with this. These remove 4 times the amount of soot over a stratapore media filter alone. But it is a bit overkill for a daily driver.
Here's the deal you need a adaptor to run either one of these filters and you need space for a Length of 7" 1/8 (181.0mm) , I have a remote filter mount kit so it's not a big deal. But I'm not sure if this would fit on the D4D engine due to size.
But here is the adapter you would need and the only place that makes it.
Bypass Engine Oil Filter Converter~1"-16 X 3/4"-16~New | eBay
The other sizes these come in simply just won't fit most vehicles but with this adaptor or using a remote oil filter kit you could run it. You just might find the BD7317 in the Philippines since it's fits many refrigeration units and tractors and Generator sets.
The Baldwin is the second best of the two but no where near the longevity of the fleetguard due to the stacked disk media it has. But it does filter at 5 microns but just does not hold as much dirt/soot. They are both excellent. And to give a comparison.
The BD28 25 microns absolute and 12 microns nominal (single pass = 50%) so it's 50% efficient at 12 microns which is very good.
The B7317 is 50% efficient at 5 microns so you see the difference.
Here they are cut open side by side.
The fleetguard is very unique
But if you have the space for one of these to fit and can get someone state side to get you the adapter then you will have the cleanest oil next to a full blown bypass system which is only 98% or so at 2 microns but very expensive.
You can get 20k to 30K between oil changes with dino CI-4 oil and up to 40k with full synthetic. The B7317 is much cheaper than the fleetguard and the best bang for the money out there if it fits. These two filters are the new favorite of Dodge Cummins truck owners.
But with the D4D your most likely going to need the full remote filter kit like I have but you would only need it for a single filter not two filters like mine which is total overkill it's triple over kill now that I am adding the new Venturi Filter.
