Most Baldwins do not come in plastic, they are in there own box for the most part especially on the small filters. Only the very large filters come in full plastic wrap because they do not come in their own box. I probably have about 100 of those BT223 in my storage so you got the real deal.
hey dvldoc, thanks for the info again. was wondering what is the difference between the the bt223 and b33 aside from the physical size.
b33 is the cross reference of oem.
i read somewhere that the bypass pressure is not the same. i think 8 for the bt223 and 14 for the b33. Im not sure of the actual numbers. i prefer the bigger physical size of the 223 but im concerned on the bypass pressure.
also are all microglass filter element, say of baldwin, are the same? im thinking if its microglass, the filter element must be the same and difference would be the thread, bypass valve and physical construction. am i correct?
Thanks in advance!
