The one at g. araneta is nearer to me.. its not cheaper from the distributor but i think i save a lot of gas going to the distributor.
The larger one (part no. 51515 for everest gen1) is a priced at 199 pesos
the smaller one (part no. 51365) for the pajero gdi which has also many vehicle applications is priced at around 150 plus..
the MOs2 is priced at 600 pesos, while the diesel purge is around 600 pesos also, they also have diesel fuel additive that cleans the injectors, valves, fuel line and injection pump internals..
Super Diesel Additiv (LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Super Diesel Additiv)
Injection Reiniger (LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Injection Reiniger)
Cera Tec( LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Cera Tec)
Oil Additiv ( LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Oil Additiv)
im going to add the CERA TEC on my next oil change, its a ceramic additive that bonds to your metals (good for 40,000kms before reapplication) "Cost 1500 pesos" <2 microns so its safe for all filters...
for diesel purge, i wanted to try this: Diesel Purge Mercedes diesel maintenance tips
600 is already cheaper than most stores.
sorry for the OT,
BTT: the thing thats stopping me from using oil additives is the thought that it might ruin the chemical compounds/mixture of the oil im using. BTW, currently, im using bosch filters. im just not sure if its the same with the bosch premium filters shown above.
i dont think there will be any problem... liqui moly has been in the biz for decades.. hehhe..
just called the distributor of wix. too bad they dont have the filter for 4m40 engine.
since TS allowed discussion also of engine oils products, since he always recommended CJ-4 API rating, i have a question i read some articles over net that it is best to use CI-4 plus or lower ratings than the CJ-4 rated oil for 2007 and lower car model, can you have some inputs on this? coz i'm confuse since zinc(Zn) and phosphorus (P) are important important anti-wear and tear protection balanced with detergent additives but they reduce it on CJ-4 because of environmental restrictions and some engine oils compensate of lower Zn & P with higher moly but some says it abrasive and deposit forming...
moly is not designed to become an abrasive product, actually it prevents abrasion... i assume you will be using your vehicle at least once a month(some particles of moly may settle if vehicle not used in long periods)... the moly is suspended on the oil, it not like water and oil... try to read the links i've given to be enlightened.. hehehe..
mos2 technical reviews - Bob Is The Oil Guy
LubroMoly MoS2 unbiased butt-dyno results... - Bob Is The Oil Guy
Liqui Moly (or Lubro Moly) Ceratec and info about - Bob Is The Oil Guy
moly additive? - Bob Is The Oil Guy
Rubbing surfaces with Moly have a much longer life. Because Moly will withstand pressures to 500,000 lbs per square inch and temperatures to 750 degrees F, it has become popular for use in greases for ball joints, wheel bearings, U-joints and many other high temperature and high pressure points on trucks, automobiles, tractors and aircraft.
Load bearing ability 250,000 psi
Density 5060 Kg.m
Melting Point 1185* C decomposes
Lubrication Temperature Range Ambient: from -185* C to 350* C
Magnetism Non-Magnetic
Coatable Substrates Iron, Steel, Aluminum, Copper, other Metals, Plastics and Man made Solids
Compatibility
im not against liqui-moly actually im planning to use ceratec on 15k COI (since i had i doubt now on moly additives) and MAG1 Product Details - Mag 1... i only raised my concern when i read this Oils: What motor oil should I use? Which oil is best for my Porsche or aircooled engine? even though it is for air cooled POSCHE. but the article discuss how CJ-4 affects car made prior to 2007...
Category SJ SL
Maximum cam plus lifter wear 30 20
Sludge buildup 9 7.8
Varnish rating (higher is better) 5 8.9
High temperature deposits 60 45
High temperature volatility 70 10
As one can see just going from the previous SJ to the SL rating is a significant
(Motor Oil 107 - Bob is the Oil Guy)
Please note that it makes no difference what oil you are using. The 0W-20 Mobil 1 that is SL rated meets the same criteria as that SL rated 10W-30 synthetic or mineral based Pennzoil. That SJ or in particular that SH oil some people are looking for (from their older automotive owners manual) is no where near as good as any SL oil of today. Always use the most currently available, highest rated motor oil, even in the oldest, most worn engine. You may require a thicker grade but just make sure it is SL or SM rated.
Concern: People are worried about the SM oils not having as much ZDDP as the SL and older oils. The reason ZDDP has been used for years is not because of its superior performance but rather its low cost and dual function as an antioxidant. It also has anticorrosive properties.
For cars, it is usually better to use the oil with an AP approved rating that is latest.
Fasten your seatbelt! Or else...Driven To Thrill!
Im currently using TOP 1 HP Plus Synthetic Blend 10W-40 with API SM certification...
with Wix filter.![]()
