Page 37 of 195 FirstFirst ... 273334353637383940414787137 ... LastLast
Results 721 to 740 of 3899
    Jun 2007
    #721
    Quote Originally Posted by miko101130 View Post
    Just want you guys to know i have been also using LIQUI MOLY MOs2 additive.. molybdenum additive... i have just topped with it 3 days ago when i had my change oil... an extra layer of protection so they say.. hahah.
    whats the ratio of this additive between the oil?
    Dec 2007
    #722
    Good goly that's a lot of Moly
    #723
    523 Auto Detailing (bought my Mos2 here, most of the items are available in this shop)
    12 G. Araneta Ave. Brgy. Imelda, Quezon City
    715-6459
    Automax Detailing Corp.
    3637 Bautista St Bgy Palanan Makati City
    834-6302
    Benzland Auto Parts
    4841 Valderama St. Brgy Pio Del Pilar Makati City
    844-2553
    Car Guard
    Stall 3 & 4 Motor Town Alabang Muntinlupa
    772-5824 /
    772-5680
    De Best Investment Corp.
    402-D Auto Cluster West gate Center Alabang Muntinlupa
    771-2103 to 04
    FB Ladao Sales Inc. (Bridgestone)
    73 Timog Ave. Quezon City
    928-4653 /
    922-7793
    Zee Car Plus Service Center
    133E Aurora Blvd., San Juan Metro Manila
    726-9116
    ok sir. i thought you got it from the distro as well hehe para cheaper.
    anyway, regarding wix filter, how much was it? for comparison lang with other brands hehe
    Dec 2009
    #724
    that can is 300ml... it can be used for up to 7 liters of oil... my ride is a pajero gdi... its quiet already when we got it.. now its silent as night when running idle... hahaha.
    Dec 2009
    #725
    The one at g. araneta is nearer to me.. its not cheaper from the distributor but i think i save a lot of gas going to the distributor.
    The larger one (part no. 51515 for everest gen1) is a priced at 199 pesos
    the smaller one (part no. 51365) for the pajero gdi which has also many vehicle applications is priced at around 150 plus..
    Dec 2009
    #726
    some pics of filter internals
    #727
    nice. the wix is not expensive at all!! will hord na! haha
    regarding liqui moly. i know its a good brand. i have been wanting to try the diesel purge. will try the mos2 too next oil change. i hope it will not cost an arm and half a leg hehe!
    Dec 2009
    #728
    Dec 2009
    #729
    the MOs2 is priced at 600 pesos, while the diesel purge is around 600 pesos also, they also have diesel fuel additive that cleans the injectors, valves, fuel line and injection pump internals..
    Super Diesel Additiv (LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Super Diesel Additiv)
    Injection Reiniger (LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Injection Reiniger)
    Cera Tec( LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Cera Tec)
    Oil Additiv ( LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Oil Additiv)
    im going to add the CERA TEC on my next oil change, its a ceramic additive that bonds to your metals (good for 40,000kms before reapplication) "Cost 1500 pesos" <2 microns so its safe for all filters...
    #730
    for diesel purge, i wanted to try this: Diesel Purge Mercedes diesel maintenance tips
    600 is already cheaper than most stores.
    sorry for the OT,
    BTT: the thing thats stopping me from using oil additives is the thought that it might ruin the chemical compounds/mixture of the oil im using. BTW, currently, im using bosch filters. im just not sure if its the same with the bosch premium filters shown above.
    Dec 2009
    #731
    i dont think there will be any problem... liqui moly has been in the biz for decades.. hehhe..
    #732
    just called the distributor of wix. too bad they dont have the filter for 4m40 engine.
    Dec 2009
    #733
    try the retailer store of donalson in 5th avenue.. PALEENO AP
    Jul 2011
    #734
    since TS allowed discussion also of engine oils products, since he always recommended CJ-4 API rating, i have a question i read some articles over net that it is best to use CI-4 plus or lower ratings than the CJ-4 rated oil for 2007 and lower car model, can you have some inputs on this? coz i'm confuse since zinc(Zn) and phosphorus (P) are important important anti-wear and tear protection balanced with detergent additives but they reduce it on CJ-4 because of environmental restrictions and some engine oils compensate of lower Zn & P with higher moly but some says it abrasive and deposit forming...
    Dec 2009
    #735
    moly is not designed to become an abrasive product, actually it prevents abrasion... i assume you will be using your vehicle at least once a month(some particles of moly may settle if vehicle not used in long periods)... the moly is suspended on the oil, it not like water and oil... try to read the links i've given to be enlightened.. hehehe..
    mos2 technical reviews - Bob Is The Oil Guy
    LubroMoly MoS2 unbiased butt-dyno results... - Bob Is The Oil Guy
    Liqui Moly (or Lubro Moly) Ceratec and info about - Bob Is The Oil Guy
    moly additive? - Bob Is The Oil Guy
    Rubbing surfaces with Moly have a much longer life. Because Moly will withstand pressures to 500,000 lbs per square inch and temperatures to 750 degrees F, it has become popular for use in greases for ball joints, wheel bearings, U-joints and many other high temperature and high pressure points on trucks, automobiles, tractors and aircraft.
    Load bearing ability 250,000 psi
    Density 5060 Kg.m
    Melting Point 1185* C decomposes
    Lubrication Temperature Range Ambient: from -185* C to 350* C
    Magnetism Non-Magnetic
    Coatable Substrates Iron, Steel, Aluminum, Copper, other Metals, Plastics and Man made Solids
    Compatibility
    Jul 2011
    #736
    im not against liqui-moly actually im planning to use ceratec on 15k COI (since i had i doubt now on moly additives) and MAG1 Product Details - Mag 1... i only raised my concern when i read this Oils: What motor oil should I use? Which oil is best for my Porsche or aircooled engine? even though it is for air cooled POSCHE. but the article discuss how CJ-4 affects car made prior to 2007...
    Dec 2009
    #737
    Quote Originally Posted by MrQ5 View Post
    Category SJ SL
    Maximum cam plus lifter wear 30 20
    Sludge buildup 9 7.8
    Varnish rating (higher is better) 5 8.9
    High temperature deposits 60 45
    High temperature volatility 70 10
    As one can see just going from the previous SJ to the SL rating is a significant
    (Motor Oil 107 - Bob is the Oil Guy)
    Please note that it makes no difference what oil you are using. The 0W-20 Mobil 1 that is SL rated meets the same criteria as that SL rated 10W-30 synthetic or mineral based Pennzoil. That SJ or in particular that SH oil some people are looking for (from their older automotive owners manual) is no where near as good as any SL oil of today. Always use the most currently available, highest rated motor oil, even in the oldest, most worn engine. You may require a thicker grade but just make sure it is SL or SM rated.
    Concern: People are worried about the SM oils not having as much ZDDP as the SL and older oils. The reason ZDDP has been used for years is not because of its superior performance but rather its low cost and dual function as an antioxidant. It also has anticorrosive properties.
    For cars, it is usually better to use the oil with an AP approved rating that is latest.
    Dec 2009
    #739
    Im currently using TOP 1 HP Plus Synthetic Blend 10W-40 with API SM certification...
    with Wix filter.
    #740
    with Wix filter.
    miko, how much is the top1 HP plus?
Remote bypass oil filtration
