Page 573 of 658 FirstFirst ... 473523563569570571572573574575576577583623 ... LastLast
Results 5,721 to 5,730 of 6580
    Quote Originally Posted by attyallanlatras View Post
    Has anyone used MITASU ULTRA DIESEL CI-4 5W-40 100% Synthetic? I saw it at Blade for P1899.00 per 4 liters. Is this a good synthetic oil?
    here is the link for its complete description: MJ-212. MITASU ULTRA DIESEL CI-4 5W-4 1% Synthetic - MITASU OIL CORPORATION, JAPAN
    The manual for my vehicle (Fortuner) recommends 5W30 Fully Synthetic with the following Oil Grade: API CF-4, CF or ACEA B1
    On the other hand, the MITASU is 5W40 Fully Synthetic with the following Oil Grade: API CI-4/CH-4/СG-4/CF ACEA A3/B3, A3/B4, E7
    Should I go for the MITASU?
    mas maganda to..
    if price is a concern..zic is affordable
    dark elf movie
    3fiddy per litre at tgc
    Feb 2017
    #5723
    Hello All,
    May nakatry na ba netong engine oil na ito? USLube Metax Extreme 5W-40
    Sent from my ONEPLUS A5010 using Tapatalk
    Quote Originally Posted by 94mitsukid View Post
    Hello All,
    thats just a rebrand, PDS looks the same...
    .: United Oil :. - manufacturing, product development and marketing of lubricants and oil specialties for automotive, industrial and marine applications. this is their supplier/bottler
    locally available ... same bottle design...
    https://shopee.ph/United-Oil-United-...356.1133393541
    #5725
    Mararamdaman nyo ba agad agad yung difference if you use a fully synthetic oil vs just a mineral oil? Or would it be the long term effect?
    if you read posts on bobistheoilguy forums.. many use mineral oils like the PYB, this is the shell helix hx5. and they've done over 200,000mi with them.
    truth is all you need is to follow your cars recommendation, time based oil change interval because of our traffic. you can follow distance based based oil change intervals if you're in other parts of the world lol.
    #5727
    Just to clear up something about Isosyn tech that in Caltex Delo gold ultra oil if you notice in it's MSDS it's different then normal group II oil, It's actually classified as Group II plus. And has been proven to protect as well as group III (synthetic) It also has a heavy additive package.
    Solvent dewaxed heavy paraffinic distillate
    Hydrotreated heavy paraffinic distillate
    Solvent refined heavy paraffinic distillate
    KEY PROPERTIES
    SAE Grade 15W-40
    Density at 15°C, kg/L 0.89
    Base No., D2896 mg KOH/g 10.2 Has a good TBN
    Flash Point, °C > 215
    Pour Point, °C < -24
    Sulfated Ash, %m 1.4
    Viscosity, cSt at 40°C 115
    Viscosity, cSt at 100°C 15.1
    Viscosity Index 137 (same as most group III oils) That's why it performs as well as group III
    PERFORMANCE CHARACTERISTICS
    API CI-4, CH-4, CG-4, CF-4, CF, CD, SL
    ACEA E7-08, E5-02
    Cummins CES 20078, 20077, 20076, 20072, 20071
    JASO DH-1
    Mack
    EO-N, EO-M Plus
    MAN M 3275
    MTU Category 2
    Mercedes Benz
    228.3
    Renault
    RLD-2
    Volvo VDS-3
    When you see the Cummins rating you know it's good god oil.
    Sir, *dvldoc, I know this is an old post but after reading it and comparing it with the specs of TOTAL RUBIA TIR 7400 15W-40, I wonder if this Total multi-grade mineral oil is as good as the Caltex Delo gold ultra oil as you have described above:
    Here are the technical specs of the Total oil for diesel engines:
    SPECIFICATIONS
    API CI-4/CH-4/SL
    ACEA E7
    MANUFACTURERS’ APPROVALS
    Cummins CES 20076/77/78
    Kamaz
    Mack EO-N
    MAN M 3275
    MB-Approval 228.3
    Renault Trucks RLD-2
    Volvo VDS-3
    MEETS THE REQUIREMENTS OF
    CATERPILLAR ECF-1a
    DAF
    IVECO
    SCANIA
    ISUZU
    TOTAL RUBIA TIR 7400 15W-40 Method Value
    Density at 15°C kg/m3 ASTM D1298 888
    Kinematic Viscosity at 40°C mm2/s ASTM D445 98.7
    Kinematic Viscosity at 100°C mm2/s ASTM D445 13.4
    Viscosity Index - ASTM D2270 136
    Flash point °C ASTM D92 236
    Pour point °C ASTM D97 -30
    T.B.N mgKOH/g ASTM D2896 11
    Sulphated Ash % m/m ASTM D874 1.45
    Is the Total RUBIA TIR 7400 15W-40 a good mineral oil for my Fortuner Dsl 2016?
    Sep 2018
    #5728
    There's a huge difference between synthetic oil and mineral oil. In terms of the performance of the car, its highly recommendable to use synthetic oil as it has high resistance power, can withstand high temperature and most importantly it provides high performance. Despite its cost, synthetic oil lasts longer which avoids constant oil change. However, you can visit your trusted car shop to ask for better recommendation and know its risk that might ruin the car over the years. Hope this helps!
    #5729
    One of the claims of manufacturers is that using Fully Synthetic Oil improves fuel economy.... But after some readings in the net it appears that it is a myth. So the benefit of using Fully Synthetic Oil is more on the duration of the use of such oil in the engine such as 10,000 km vs the mineral oil which has a life of not more than 5,000 km. My concern now is the viscosity of the oil. The manual recommends a 5W 30 viscosity, but that if for fully synthetic oils which costs around 3 times (around 5k pesos) than a mineral oil which cost 1.5k. The mineral oil is at 15W 40 (pasok naman sa manual as minimum).... Some say that since we do not have winter in the Philippines so the first number does not really matter. It is the second number which is crucial. I have read that 40 is too thick as an oil and might have some issues in the long run.... Is this true?
    #5730
    If the manual recommends a w30 then follow it by all means lalo na if brand new vehicle. Mas maliit pa tolerances niyan compared sa previous engines nga gawang 90's eh so magbenefit talaga engine sa lower viscosity dahil mas magaan i-circulate ng engine.
    But if you say that the w40 is also in the manual, then pwede din yan of course. Lalo na if diesel engine. Kayang-kaya niya yan.
Mineral , semi synthetic or fully synthetic?
