i think its the same for Rimula R4x. it was designed to be used for trucks and mining equipments.
there is a rimula r4 L for cars with dpf.
Shell Rimula R4 L - Philippines
http://www.shell.com.ph/products-services/on-the-road/consumer-lubricants-tpkg/trucks/shell-range-truck-heavy-duty-engine-oils/low-emission-multi-grade-oils/rimula-r4-l.html
Guys, due na ko for change oil. Which is better? Zic a+ 5w-30 or shell helix ultra with pure plus tech 0w-40 (both fully synthetic). For vios. Thanks
afaik, cheaper ang zic a+, pero as per experience, mas gusto ng 1.3 vios namin yung 5w40 helix ultra with pure plus compared to 10w40 na zic a (semi-syn).
Shell Helix HX7 Diesel with pureplus 10w40 ba magkano? Have you checked their price? Wala pa sa supplier namin eh.
wala pang HX7 na may pureplus. helix ultra lang meron pure plus tech. retail ng station nasa 700-720/liter. pero nakakita ako online nasa 500/liter yata
quote ng distributor sa akin 638/liter yung helix ultra. 296 naman for HX7.
but i am currently using Rimula R4X sa mga diesel engine. CI-4 tapos 180/liter
but i am currently using Rimula R4X sa mga diesel engine. CI-4 tapos 180/liter![]()
Currently using zic a semi-synthetic. So far ok naman. Plan ko mag change to fully synthetic para compare difference. Kung mas fuel efficient at mas malakas hatak.
Tried zic xq 5w40. So far so good. Engine is quiet as if i did not start the engine.
May Shell Helix Diesel HX5 15w40 with Pureplus tech na sa supplier namin. P1,290 ang 6L jug.
mura yan kung pureplus na yung HX5. last time na check ko is Ultra lang meron. the rest is "active cleansing technology" lang. kukuha ka? pa-picture naman and ano API rating?
I am due for 10k PMS next month, on my previous PMS I used oil provided by the casa but this time I am planning to buy 1 on my own. It is said in my car's manual that I should use SAE 5W-30 oil... anu magandang brand ng oil with the same specs.
Thanks in advance po...
if kasya sa budget mo i would suggest go with the new shell with pure plus...
piliin mo lang yung same spec required sa manual mo, im sure meh equivalent yan...
it took shell more than 20 years to mass produce the product and develop the technologies para maging mainstream,
ito ang forefront nang engine oil
Saan ba nakaka bili nung shell helix ultra with pureplus? if you can also mention the price it can help a lot.
TIA
TIA
