kuya baket malabo mga picture mo. are you using tsikot app or an external picture hosting page?
less than 300 per bottle?
postimage papi...got a better one?
imgbb.com
after uploading select the bb code
copy paste
how to upload a photo on fb
havoline energy synthetic 5w30👌
shell helix hx7
https://s8.postimg.org/eww3uj4xx/20171123_174610.jpg
pls chk if its ok
nice for cng pala. high tbn 👌
decent price. what about your transmission fluid?
top up lng? no atf replacement since 2010?
Yun ang hindi ko alam sir StockEngine. 2nd owner kasi ako.
I'll include na din siguro yung atf pag nagpa maintenance ako or maybe ipa-check ko na din kung kailangan ko na magpalit ng atf.
Sorry mga sir kung off topic... Thanks...
change the atf. it only costs a few thousands. if the transmission fails. madugo
Yes sir StockEngine and sir Papi Smith, replace ko na atf ko sa next maintenance ko. Thank you
When it comes to ATF, DW-1 or Z1?
I'll check na din yung atf na ginamit ko for top up pag uwi ko.
Sir Papi smith, no idea sir on adjusting the valve tappets or kung kailangan na i-adjust. Newbie problem.
or remove ko na lang yung valve tappets adjustment sa package then retain the rest?
Balak ko nga sana, bumili na lang ng Honda FS 0w-20 or Motul H-Tech 100 Engine Oil FS then sa talyer ako magpa-change oil and shell naman for tune up.
Mas okay kaya kung ganun na lang gawin ko mga sir?
ATF DW-1 replaces Z1, wala ng Z1 sa casa, baka meron sa labas, but I would advise you against it, baka ma jafakes ka pa.
Valve clearance is recommended to be checked every 20k based on booklet, I never had mine checked ever because I don't go to casa.
Sa oil so far I have been using FS with Mitasu as my latest, same performance pa rin sa Mag 1 FS, Idemitsu Mineral Oil and Honda Genuine Mineral Oil, so since I only cover 3.5k kms/6 months and use only Vic filter, balak ko mag Honda Mineral Oil na lang every 6 months para tipid. Sa casa, quick chamge oil, all-in is P1,195.00 for regular oil. Honda Cars Philippines' Official Website
Can't comment on the cost, but I was just thinking do those spark plugs match your car? Also, do you need your valve tappets adjusted? Di ba to adjust it you have to open the top cover? Kasi if it does not need adjustment baka pagsimulan pa ng leak ang pagbaklas kabit ng cover mo. Tina timing pa ba ang new models?
Yung ATF recommended to be changed at 40k or every 2 years, I'm running 4 years and 58k and had my ATF changed 2x na.
Add: nag reply ka na pala, to be sure, I would suggest you prioritize change of your ATF asap, alagaan mo ang tranny mo, use only Honda Genuine prescribed ATF.
if you want good fc that 0w20 would be best..
you can use naman the 40w. so while youre reading the manual, whats the recommended oil change interval? whats the oil capacity? whats the required diesel engine oil? api-cj? or acea class?
