Page 59 of 330 FirstFirst ... 94955565758596061626369109159 ... LastLast
Results 1,161 to 1,180 of 6586
    Jan 2013
    #1161
    Quote Originally Posted by Ammiel Barlis View Post
    using poor filter with good oil defeats the purpose of using good oil. If you use bad filter, particles smaller than 30 microns gets recirculated back to the engine causing greater damage in the long run. Tbn will be still be high for good oil when you do oil analysis, but particle count for wear metals in the oil would probably also increase. Bosch filters are good over the counter filters as good if not better than oem but not up to baldwin or fleetguard stardards. Mura lang naman sya so changing it every 5k is extra safeguard. Kung walang makuhang baldwin yan gamit ko
    *dvldoc ,am I right on this?
    Jul 2012
    #1163
    Ok po ba ang Royal Purple for Gasolien engines?
    Jan 2012
    #1164
    Quote Originally Posted by leodawesome View Post
    Yup. Very much. Pwede sya sa diesel or gas engine.
    Oct 2011
    #1165
    Okay, noted. thanks for your inputs sir.
    Jul 2012
    #1166
    Quote Originally Posted by bayen View Post
    Thanks boss! Follow up noob question nga pala, pano pala yung royal purple eh color purple na talaga initially. So everytime you check the engine oil kung madumi na or hindi, you cant tell kasi its dark colored talaga in the first place?
    Jan 2012
    #1167
    motor oil can immediately turn black the moment you run it in your vehicle. but this doesn't mean that it needs to be replaced right away. specially on diesel rigs but mostly because of soot. When it turns black that means its working. Its the breakdown of the additive components that you need to be more concerned of, however its impossible to determine the viability of the oil unless you have your oil tested in a laboratory. using a good oil filter prolongs the deterrent degradation of your oil. the more the oil gets contaminated with dirt, dust, etc the faster it looses its viability. that's why when you use VIC or OEMs its safer to follow the 5,000km oil change interval however if you use more efficient filters, you can extend your oil change interval to 10,000 to 12,000 km.
    Aug 2009
    #1168
    Good Day!
    I'm planning to CHANGE the ENGINE OIL of my Isuzu Trooper 4JX1 local engine. The engine oil is dark, is there a way to make the Engine Oil clearer after flushing it with a New Engine Oil? 'cause I have tried it in my Pajero, when I checked the Engine Oil after the Oil Change & Engine Flush, maitim pa rin. pls help guys on what to do?
    Jan 2012
    #1169
    Quote Originally Posted by baby_scar View Post
    Good Day!
    You can use an oil filter than filters down to 5 micron. Very difficult to achieve unless you are running a dual filter setup like what doc has. Primary filter filters down to 30 micron, secondary one filters down to 5 micron. secondary will filter out the soot that causing your oil to turn dark hence clearing out the color of your oil.
    Oct 2011
    #1170
    Good Day!
    mag dark naman talaga engine oil after prolonged used.
    #1171
    Good Day!
    Bro,- when the oil of your diesel engine becomes dark, even right after the oil change,- it is doing its job right!
    18.1K:rant:
    #1172
    Good Day!
    you can try this, kung gusto mong after change oil di magbago kaagad ang kulay ng oil mo,
    magchange oil ka gamit muna ang cheapest oil na makukuha mo, but wag munang palitan ang oil filter, let it run for a few km, then balik sa shop, drain ang oil and change filter, palit na ng gusto mong oil. yan fresh na fresh na ang oil mo.
    Dec 2009
    #1173
    combustion is a DIRTY process, especially for diesel because it a LESS REFINED fuel compared to gasoline thats why its CHEAPER.
    engines oils job is to LUBRICATE & not to collect SOOT, its just that in the process of combustion some soot find its way in the oil that is supposed to lubricate the engine to lessen wear & tear of the pistons moving up & down the engine cylinders. on the other hand its the job of the oil filter to collect the soot introduced in the oil by the combustion process to keep the oil clean & effective in protecting the pistons, however, over time, enough soot will accumulate in the oil filter & it will no longer be effective in preventing the dirt introduced by every burning cycle of the combustion process from contaminating further the oil protecting the piston. that is when the oil get sullied up & no longer an effective lubricant because soot are coarse particles. black oil color is certainly a cue for replacement.
    diesel fuel is cheaper than gasoline engine but its maintenance will never be cheap. whatever you saved in fuel cost in the long run will be taken out in the cost of more frequent oil & filter replacement or worse OVERHAUL of the diesel engine
    Aug 2010
    #1174
    any feedback sir sa redline oil mgal sir?, ka presyo lang nya motul and its group v oil.
    Oct 2011
    #1175
    Quote Originally Posted by wakiki77 View Post
    Haven't tried redline. Saan makukuha yan sir?
    Aug 2010
    #1176
    may mga shop sa banawe na nagbebenta redline oil parang 550 per liter ata, karamihan sa mga mahilig sa race and tuners eto gamit nila,
    di ko pa na try sa engine, sa transmission ko lang na try nun nagloko synchronizer ng tranny ko at kaylangan ibaba tranny, advise ng mechanic sakin na try ko muna redline oil mt-90
    gl4, yun after one month of using nag ok tranny ko, naka save tuloy ako malaking gastos.
    Anyone tried this oil?
    http://www.warrenoil.com/MSDS-Spec/P...-40%20CI-4.pdf
    Coastal Fleet 15w-40 - Bob Is The Oil Guy
    Ang mura kasi bigay sa akin, P1,998 for an 18L pail. Very tempting for our fleet eh. hehe
    Oct 2011
    #1178
    Sir, is it on par with MOtul ung Redline motor oil?
    Jul 2011
    #1179
    honga mura nga..very tempting talaga tsaka maski 3k OCI panalo -pa din para sa van ko ;-) sana mayroon mag feedback
  20. #1180
    San nabibili yung pail? Willing akong maging guinea pig!
Mineral , semi synthetic or fully synthetic?
