Okay ba Royal Purple HPS 5w30 para sa Grand Starex crdi ko?
si testa previous RP user, naging Top1 user na sa 4m40 niya and he's very happy with it. im sure you'll be happy also.
ano yung requirement ng engine mo sir? sa innova gas namin, im using Top1 SDO. since this is a multi-fleet oil and my engine requires 15w40 viscosity. so far so good.
if budget is not an issue, RP is a good oil. but 5w30 might be too thin.
yes. Synthetic Diesel Oil yung SDO. pwede siya sa gas since its originally rated API C and S. I also email Top1 regarding this since I checked their US webiste, same part number pero iba brand name sa atin, and they confirmed na same oil siya and pwede sa gas engine. just like Delo. almost 3 weeks ko na gamit sa innova and ang tahimik talaga ng engine, that even the mechanic who changed the oil noticed how quiet it was.
*crazy_boy- Whats the diff of Top1 SDo vs HD/HD plus?
Which one is better? From their website same na synthetic sila eh.
In your opinion which one is a better option.
Option 1: Use Shell R4x + vic oil filter
R4x is * 205/ltr or 800/gallon
Option 2: Top1 SDO/HD/HD+ + vic oil filter
Vic oil filter kasi walang Baldwin for the C-524.
Any inputs/better suggestion?
Thanks.
*Edit
Preferably 15w-40, yun na yung all time nakalagay sa dmax namin.
OCI is at 5-6k kms, should I opt for the SDO its at 10k kms.
question lang din mga sir.
I asked TOP1 US for the product data sheet of TOP1 SDO and here are its specs:
GRADE, SAE ASTM TEST 15W-40
Gravity,°API D-287 31.5
Flash Point, °C D-92 227
Pour Point, °C D-97 -27
Viscosity:
cSt * 100°C D-445 15.0
CCS * -20°C, cP D-5293 6000
Viscosity Index D-2270 150
Appearance Visual Bright & Clear
Color Green
TBN D-2896 9.0
ok lang ba kahit na its TBN is kinda low to be 9.0 for diesel? I'm considering this oil for our 4m40 and 4D56. thanks!
pm nyo na lang ako kung gusto nyo ng copy pds nung TOP1 SDO. hindi ako marunong magattached ng pdf.![]()
Care to share why sir?
Is't because I can't maximize the oil if I'll be using VIC?
I'll try to find the aforementioned filters, i'll add the Bosch too.
Also whats the diff bet the Top1 SDO and HD/HD+?
*Edit
Checked Baldwin website, wala talaga silang offer for the 4jj1 C-524 na oil filter.
I''ll have to find a better replacement sa VIC. Hmmm...
Top 1SDO may friction modifier kasi kaya tahimik at mas smooth ang makina. Hehe
Posted via Tsikot Mobile App
Fasten your seatbelt! Or else...Driven To Thrill!
Maganda na din ang presyo ngayon ng baldwin filter.. Hehehehhe
For the Bosch oil filters, certain kind of filter are manufactured in a certain country. ie. OM 036 is made in Korea. OF 506 made in Indonesia. This has been my experience.
Magkano ba baldwin filters? May specific model ba ako na dapat hanapin? BTW Ride is Innova '06 model.
BT223 is just right for D-4D due clearance issues with taller filters. Although I have yet to test fit something like B2 or LF3487 on our Innova D-4D.
As for vvt-i, you can easily use tall filters bec. there is lots of room down there.
OT: as for the blinking optitron, some say it could be the alternator.
How about for my ride mga sir?
Ano magandang Filters ( fuel , oil , air ) and Semi synthetic oil for
Toyota Vios 1.5G Automatic Trans 2004 model?
Currently Using Liqui Molly brand
