Results 71 to 80 of 104
November 11th, 2005 01:57 PM #72
Guys, what can you say about this new products out in the market today? They said it can add and bond a ceramic metal coating to your engine's clearances that is already due for repair. The result is a new coating that patches these clearances resulting to an almost similar effect to an overhauled engine. If you complete the treatment by adding 3 tubes of their products within 1,500kms u will notice a great effect.
Have anyone tried this? They have a website at:
http://www.xado-us.com/cgi-bin/press...?id=2004100801
http://www.xado-us.com/cgi-bin/press...?id=2004012702
Pls feedback naman dun sa mga naka-try.
November 11th, 2005 01:59 PM #73
there's already an existing thread... kindly use the search function.
http://tsikot.yehey.com/forums/showthread.php?t=21866
November 11th, 2005 02:00 PM #74
check out these previous threads about xado:
xado product
Xado testing on Sept 4 at Autoplus 10:30AM
Xado, another engine improver?
Has anyone tried the Xado?
this thread is now closed.Signature
June 4th, 2006 06:20 PM #75
Got this from tsikot Classifieds.
Something like the previously discussed Xado?
RVS TECHNOLOGY ENGINE REBUILDING GEL
Restore and preserve your engine, gearbox, differential, transmission, and power steering assemblies to factory specs.
A metal ceramic structure that is 60% harder and 100% smoother than the original metal forms on top of the old friction surface virtually halting wear and tear and restoring the surfaces to their original form.
RVS treatment is guaranteed to last up to 100,000 kms. or (60,000 miles) depending on driving condition.
BENEFITS:
...Prolonged life cycle of components (30-70%)
...Reduced replacement demand of costly spare parts as wear process almost stops
...Reduced number of expensive stand-stills and maintenance hours/days
...Improved predictability of mechanism function
...Reduced emissions - reduced environmental strain (10-50%)
...Reduced energy and fuel consumption (5-20%)
...Reduced vibration and noise level (10-50%)
...Increased lifespan of lubricants (30-50%)
...Possibility to use less expensive lubes w/less additives
...Less corrosion problems
...Survival of the mechanism in case of hazardous lubricant loss
...Reduced temperature of mechanism
...Stops blowby condition of engine which increases piston and wall compression.
...No downtime while treating engine/mechanism. Rebuilds while u drive.
June 4th, 2006 08:01 PM #78
oo nga...i actually emailed the seller and asked for more info.
yup, pretty much like xado...thats what came into mind first...
whatever happened to that anyway? either nobody wanted to have their car tested or they weren't confident enough to offer fixing whatever damage it could cause? hmm...
Tsikot Member Rank 5
- Nov 2003
- 3,849
I didn't know that Tesla is in the PH na pala. I saw one exiting our village (as I was entering). I...
Tesla Model Y
