Results 41 to 50 of 104
- Aug 2004
- 164
- Dec 2003
- 11
September 14th, 2004 12:15 AM #42sir allanroy, pwede ko ba i-volunteer yung mitsubishi lambda ko for testing? pa-email na lang po sa dyake04*yahoo.com kung willing niyo po i-test sa car ko. thanks!
April 9th, 2005 09:31 AM #43
i received a proposal for an engine improvement product, it's called Xado (pronounced as Ha-Doe) Revitalizing Gels for Gasoline and Diesel Engines (www.xado.com), and does the following:
- Engine power brought to 100%
- Increases Oil Pressure and Torque
- Decreases Oil Burn-Out loss
- Economical Repair (up to 70% savings) with no downtime and disassembly
- Increases (up to 42.5%) and equalizes compression across all cylinders
- restores geometry and weight of worn parts
- reduces friction coefficient up to 300 times
- improves mileage by 5-7%
- reduces fuel consumption at idle by as much as 30%
- lower CO (up to 24%) and CH (up to 88%) emission
- 10 times decrease on noise, vibration and harshness
there were testimonials from some individuals, the one that caught my attention was a Mr. Clemente H. Lopez, a farm manager and member of Balayan Off-Road and Nissan Patrol Club of the Philippines. to fellow NPCP members, do you know him?
a tube of Xado Gel costs P1,960.00. for engines with oil capacities of 3-10 liters, 3 tubes would be needed.
What do you guys think about this product? is this another Khaos like thingy?Signature
April 9th, 2005 10:28 AM #44
3 x P1960 = P5880. almost 190 liters of unleaded 95 na din yan, malayo na mararating ko sa 190 liters.
besides, it it's due for an overhaul, then overhaul. even if it works you will only be delaying the inevitable. tago mo na lang yung P5880 mo pandagdag sa needed repairs.
and whoever are those people who gave testimonies, i'm sure their opinions were not based on scientifically approved testing methods (you know, controlled parameters, measured results). so those testimonies are good as nothing.
April 9th, 2005 10:42 AM #46
Parang may thread na about this, the poster was allanroy... There was even a dyno test... Wala yatang nangyari.
May 19th, 2005 07:39 PM #47
up ko lang to...
My car is over 20years old... although ok pa naman, i'm pretty sure that this engine is quite banged up... Ano dapat expectation and advice na mabibigay mo allanroy? (if you still check the boards)...
- Aug 2004
- 42
May 20th, 2005 12:27 AM #48advise? although sabi mo ok pa sya, sigurado pa rin na mas bumaba na ang efficiency nya since nung brand new sya. Mag pa compression test ka or maybe oil analysis para malaman mo yung status ng engine mo.
- Aug 2004
- 42
August 6th, 2005 04:30 AM #49hindi natuloy yung dyno test kse we found out na ang problem eh sa valves after doing a leak down test, car ni VICVIC ang gamit nun... last year. kung valves ang problema, hindi to kaya repair ng Xado since hindi naman sya dinadaanan ng Engine Oil...
boybi, si Mr Clemente Lopez eh tsikoteer din.
I already resigned from Xado last Dac 2005 but I'm hoping na maging subject yung car ko for testing, my ride is a 93 ECCS, 107T mileage.
Compression Test Before and After
Dyno Test Before and After
boybi, may kontak ka pa ba sa Management ng Xado? kse kung ako magpropose sa kanila baka kung ano lang isipin ng mga yun...
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 8th, 2005 11:51 AM #50all the additives/miracle workers are pretty much a bunch of bs imo. out of all the products that have been dyno tested, none has made power so far
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
