Page 10 of 11 FirstFirst ... 67891011 LastLast
Results 91 to 100 of 104
    May 2004
    #91
    Nope.. for me sayang lang pera...
    #92
    this is what it looks like...i've tried the power steering gel and now we are under process to complete the procedure of the gel.. So far for the 1st gel..I noticed the smoke from my exhaust disappeared. And the engine noise was reduced.
  3. #93
    may thread na about this product way before those fancy packaging...
    arang makailang gamit ka ata muna to have a real result..
    #94
    Yes bro..3 tubes kailangan for 3 to 10 liters of oil..I follow the procedure talaga..pero before ka magstart, flushing muna with vitaflush...before at idling 20 lang ung oil pressure ko..ngayun 80 to 100...atsaka nawala na ung smoke sa exhaust ko..at meron nang power...
    #95
    Search, we have a thread already about this. Closing.
    #96
    theveed,
    I just merged the other XADO threads into one. Re-openned the merged thread.
    #97
    WOW!!!! Its really hard talaga to prove everybody that this product works..Well, for me it works...Just try it yourself nalang mga bro..para kayo mismo makatestify...ako i try it, kasi subject for overhauling na sasakyan ko...I take the risk nalang...for me worth the risk namn..
    #98
    Quote Originally Posted by jinrai View Post
    dami pa rin nag papa general overhaul e.. i guess di sya kasing effective as claimed?
    Ofcourse overhauling di talaga mawawala yan....Xado will just fix clearances and wore out cause by metal to metal friction..Lahat ng clearance sa cylinder wall ( Liner ) at ring magbebuild up sya ng cermet ( ceramic metal )....atsaka mga wore out bearings sa engine moh..that why when you use xado, you'll notice a quiet engine, no excessive smoke sa exhaust, mataas na compression at oil pressure,more power and fuel efficiency about 15% to 30% ..Xado never over build up...Xado can not fix leaks from valve seal, oil seal or rubber gaskets...
    We still need overhauling pag naputol ring or once maputolan ka ng timing belt....
    #99
    Xado can really save your engine from costly repair...and also 15% fuel..heheheh
    Apr 2008
    #100
    xado ... mukhang wlang conclusion tong thread nato a? does it work or not? walang proof e pati yung supposed testing hindi rin natuloy? allanroy not posting anymore? hehe
[MERGED] XADO engine treatment thread
