Results 41 to 50 of 82
BANNED BANNED BANNED
- Jul 2013
- 421
June 30th, 2017 12:57 PM #41Niky, Dr D, OJ88, etc., I do not have to prove anything to you, what for? "Nasubukan" ko na ang magnetic device from UK. Hanggang 10% lang ang fc improvement. Made my 1998 L300 run more silent, too.
Q: "Nasubukan niyo na bang gumamit nito sa euro 2 engine?" (Pls dont use on euro 4 engine, because it may confuse the ecu, then, it will have to be reprogrammed)
Pls make subuk-subuk, then, make comment; otherwise its 'fake news'.
- 54,289
- Jul 2013
- 421
June 30th, 2017 01:08 PM #43[QUOTE=dr. d;2847907]Sir, di ba lucky na na ako dahil this is my 50th? Ang kuya ko, hanggang 2-3 lang. Remember the 2 ABS-CBN directors na natagpuan na lamang na malamig na bangkay; at maraming pang iba?
Doc, mula ngayon, I will try to take meds for my hpb (together with the iso-tone), and also for my vertigo, and stomach gas.
A friend who is taking some meds for hbp said it costs P5-P10. Mura lang naman pala. Thank you doc.
Pero, make subok-subok, pls.
- 54,289
June 30th, 2017 01:13 PM #44[QUOTE=pyramid00;2847918]that would depend on your definition of "hypertension attack".
to some people, they define it as any blood pressure reading over 140/90. their "attacks" occur every day. that's over 300 "attacks" a year.
to others, if they are still able to stand up and walk, "it's not an attack".
- Jul 2013
- 421
June 30th, 2017 01:13 PM #45
- Jul 2013
- 421
June 30th, 2017 01:17 PM #46
- Jul 2013
- 421
July 4th, 2017 02:04 PM #47Sir, hindi pala pwede ang nuvi-nuvi sa modern engines. Last time we installed on a fortuner, parang nalulunod. When the 02 sensor 'sees' the increase in 02 flow, it will interpret this as a lean burn, so it will dump more fuel. The 'cure' would be to use an EFIE device. If imported, this will cost 50-100usd. There are circuits on the web, so i could make one, but that would be much later. (Sa crosswind specs, baka pwede.)
I only know about the dyno testing facilities of Speedlab. (P4k-5k/test before) We wuld like to test our device on a dyno; before and after lang on our Nissan Sentra 1994 for our own peace of mind, probably next month. Meron pa bang dyno testing facilities sa MM aside from Speedlab? Yong pinakamura?Last edited by pyramid00; July 4th, 2017 at 02:08 PM. Reason: spelling
July 4th, 2017 02:36 PM #48
Extraordinary claims require extraordinary evidence. It's the claimant who bears the burden of proof, not the critics.
Lots of dynos here. If the manufacturer or distributor is really interested, it is very easy to set up an impartial test.
Also, I improved economy 10-15% with nothing but illustration board and duct tape. But I actually documented and tested this via an A-B test with multiple data points.
http://www.topgear.com.ph/features/f...g-a36-20160402
Only reason I haven't done this on my personal car is a.) It looks ghetto, and b.) I don't have the time to fab up a better looking fiberglass kit.
- Jul 2013
- 421
July 4th, 2017 09:34 PM #49
Sir, we dont want to give proof about the performance of nuvi-nuvi. We owe it to ourselves to be satisfied with the expected results.(whatever the dyno results will be). What we want to do is; have our old vehicle be dynoed on a monday, install the device/s and come back again on the next monday for the 'after' test. Walang gagawin sa car except use it between manila and cabanatuan.
I dont know the mechanics of decreasing a 10%-15% fc using board and duct tape. What is the principle behind that?
This dyno test will be on power increase, isnt it? A - B test only. No test on fc, smoke reduction or whatever. Only a dyno result. Is it still p4k/test with speedlab? Thanks for any info.Last edited by pyramid00; July 4th, 2017 at 09:37 PM. Reason: spelling
July 4th, 2017 11:28 PM #50
I don't have to try it to know it's crap. I know how to appreciate good piano music even if I can't play a single tune. By the same reasoning, I will be skeptical to any product that sells itself as a cure-it-all.
It's a fake product.... along with all them 'miracle' gadgets.
Ma-coconfuse yung ECU warranting a reprogramming? From what, 'magnetized' fuel? LOL! You're forcing anting-anting type logic and passing them off as science.
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
