Quote Originally Posted by vanityq View Post
Already changed the Distibutor cap and Tension wires, i noticed changes in speed and acceleration gumanda hatak niya.
been using the van everyday for straight 1 week with at least 25km/day.
then pahinga sa bahay for 4days(mon-thur)
used it again on friday and okey naman lahat
but bigla nanaman akong itinigil nanaman ako the next day saturday(kahapon ito) but nagstart naman uilt after few minutes.
could it be the gasoline kaya? may halong tubig... im filling my tank at petron bf
vanityq, sori ngayon ko lang napansin pm mo...sa ibang site lang kasi tayo nagkakareplyan dati e....anyway heto yung nakasolved sa problem ko sa vanette ko...pero di ko sure kung magkapareho tayo ng naging cause..pero ang ibig ko sabihin is sa distributor ang problema..sa ignition system pa rin kya intermittent tirik sakin dati... same din, napalitan ko na lahat kaya bago na lahat ignition system ko including ignition switch,,pero tirik pa rin until nahuli ko sa distributor assy. check mo post ko last time...see below...
sa E10 fuel...ok lang ...di ka ititirik dahil natry ko na gumamit...madali lang makasira ng parts pag di pa e10 compatible ang material.
cvt, sa ngayon ok na ulit yung vanette ko. it's been two weeks now of observation and verification...confirmed ko na rin yung culprit. i got different case of trouble. nasa ignition system yung problema and it was induced by mechanical failure of distributor. yung unstable movement ng tachometer is caused by worn out breaker plate bearing, kaya pabagobago ang idle speed and until mamatay na sya sometimes on idling..then yung biglang namamatay while cruising is dahil sa offset pala yung alignment ng rotor sa distributor cap contacts. yung misalignment ay dahil sa nagpalit ako ng arm ng vacuum advancer dati pa..mga 3 year ago na because nasira na yung una pa..leaky na yung canister..ibang vacuum canister yung pinalit ko kaya pinahinangan ko lang ng ibang arm..medyo napahaba kya na-offset yung rotation ng breaker plate. since na bago yung rotor and cap before, nakakatalon pa yung high voltage between contacts and nung mapudpod na, lumaki na yung gap..this now resulted to misfiring and stalling...when i repaired the old distributor, i got good response so last saturday bumili na ako ng surplus sa banawe...so ngayon stable na ulit yung van. sa ngayon xcs gamit ko na fuel...E10 is bad for local parts..yung pickup screen nung bago kong fuel pump e na-deformed at natanggal sa pump dahil lumuwag..buti binunot ko ulit yung pump for checking kya nakita ko..ikinabit ko ulit yung lumang original..anyway mga vanette owners, salamat sa mga inputs and tips about troubleshooting, great help satin lahat to.. safe driving to all.
