Update on my Intermittent Problem: (vanet gas engine Still Stalling)
Found out last weekend na gasoline problem, after 30minutes of driving namamatay na siya and will start after 3-5 minutes. Check the tension wire and may karga naman ng kuryente upon checkin.
Already replaced the following accordingly:
-Fuel pump
-Fuel Filter
-Ignition Coil
-Distributor Cap
-Tension Wires
-Cleaned the carburetor
-removed strainer going to carb
-Newly tunedup and adjusted the contactpt/condenser
Parang nawawala bigla ang gasolina and sudden stall will happen.
What else to check other than this:?
-Fuel lines
-Fuel pump relay
-rotor distributor
may kinalaman din kaya itong mga ito?
what could be the EXACT problem. Suggest pa kayo, nakakaiyak na ito.
