Results 1,991 to 2,000 of 2348
- Sep 2006
- 1,335
- Sep 2006
- 1,335
April 9th, 2013 12:40 AM #1992
- Feb 2007
- 24
April 9th, 2013 05:39 AM #1993My 2007 Ford Ranger Trekker 2.5 AT has terrible fuel consumption. I already changed all the fluids, filters(air, fuel), even had it diagnosed by Berrima who performed fuel line purge on it, to no avail. When I got the unit, there was a mild knocking sound and CEL which turned out to be the EGR whic I also replaced. We tried cleaning it first but the problem persisted. All of these and I'm still getting 5.5-6 KM/L city. What's annoying is that even on long trips such as Subic/Baguio, the best that I can do is 7.5 KM/L. It is also spewing black smoke during sudden acceleration and when the RPM goes over 3K RPM. I also have an OBD2 scan tool and from the reading, it seems that my injectors are working fine (via pressure reading). It also experience surging in terms of throttle response which I thought was due to a faulty Accelerator Pedal Position Sensor which I also replaced and tested, but still the symptoms persisted.
The only thing that I haven't done is to have the intake manifold cleaned. Do you think this will solve the high fuel consumption/black smoke problem during high RPM's? Do you have any other recommendations?
April 9th, 2013 08:12 AM #1994
- Sep 2006
- 1,335
April 9th, 2013 11:58 AM #1995
- Sep 2006
- 1,335
April 9th, 2013 01:05 PM #1996
- Feb 2007
- 24
April 12th, 2013 09:25 AM #1998
April 12th, 2013 09:28 AM #1999
April 12th, 2013 11:09 AM #2000
would blanking plates sa EGR ng D4D engine cause any issues? would it help in fuel consumption sir and pass the emmission tests? thanks sir Dieseldude
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
