Page 87 of 118 FirstFirst ... 377783848586878889909197 ... LastLast
Results 1,721 to 1,740 of 2351
    Sep 2006
    #1721
    Quote Originally Posted by cokezero View Post
    sorry sir, nakalimutan ko hehe isuzu ls/tfr 1994 model.
    pansin ko po kasi hindi ganun kalakas yung white smoke pag idle pero mapapansin mo na may usok talaga.. tapos pag nag sshift po ako sa 3rd gear makikita mo nag eemit ng medyo makapal na white smoke.. sa 3rd gear lang nangyayari sir..
    Check injection pump timing
    Check valve clearances
  2. #1722
    Quote Originally Posted by kompressor View Post
    Dieseldude,
    I noticed that I started having fuel backflow problems after I replaced my fuel filter. The former one was an Asahi brand while the replacement was something really el cheapo (Sakura or something similar sounding) as I had no time to get one during the time I changed it. Do diesel fuel filters also have one way check valves like those in oil filters?
    If not, how about feed/primer pumps? Are they equipped with a one way valve? Or am I missing a fuel check valve along my fuel plumbing?
    Up ko lang yung query ko.
    Are there other users who experienced similar fuel back flow issues? Basically, the result is having to occasionally pump the feeder by hand till the fuel reaches the injection pump (pag bumigat na yung pump, it will start with one click). I'm using an FC321 but planning to change to a Baldwin BF7534 (4D56 application).
    Sep 2006
    #1723
    Of course, we often see this condition.
    Atmospheric air is getting into the injection pump, hoses and gaskets, or filter assembly when engine is not running. Check for worn sealing gaskets or loose fittings.
  4. #1724
    Thanks! I'll check for air leaks or loose fittings then. Will also check the filter baka kulang sa higpit both filter and water separator.
    #1725
    hello dieseldude, i own a kia sportage gen1 kr2 2.0l diesel, model 1997 i think. any idea on why sea-oil diesel gives a low rpm - flat on the 2/3 line at idle as against shell/petron which a tad higher around 5rpm. power's about the same on highway or hilly roads. location is Zamboanga City. thanks, this thread is most useful and practical. more power!
  6. #1726
    Quote Originally Posted by Dieseldude View Post
    alright, salamat sir!
    Jan 2012
    #1727
    Dieseldude, is it true that Montero Sport Non-VGT's engine is "sirain" in the long run? Some people told me that the 4d56 engine is just good at first. They didnt tell me naman kung ano yung mga "sirain" na yun. I'm just scared. Any thoughts on this engine? TIA.
    Sep 2006
    #1728
    You're welcome.
    Sep 2006
    #1729
    Dieseldude, is it true that Montero Sport Non-VGT's engine is "sirain" in the long run? I don't think so.
    Some people told me that the 4d56 engine is just good at first. They didnt tell me naman kung ano yung mga "sirain" na yun. I'm just scared. Any thoughts on this engine? TIA. I have friends who have this car and they're very happy with it.
    Jan 2012
    #1730
    Thanks dieseldude!
  11. #1731
    I think I found where the air leak is. I disassembled the feed pump assembly and tried pumping with the inlet port closed. To my surprise, I barely felt any suction and the hand pump will just return to its original position, indicating a possible air leak. Removed the fuel filter, covered the holes and pumped, same thing. I went to an auto supply just to check how a brand new feeder pump behaves and presto, the pump will stay pressed down if I pumped with the inlet port plugged. Bought the new feeder pump for P330 pesoses.
    I checked the old feeder pump after disassembly and to my horror, the diaphragm was ripped! It was probably destroyed when the gas station mechanic started pumping after I had the filter replaced a month or so ago. And as per my observation, the pump's palm rest is stuck to the shaft (which should normally turn without moving the shaft) so a slight circular movement of the palm while pumping might have ruined the diaphragm, no thanks to the gas station mechanic.
    Installed the new feeder, transferred the fuel filter (since it's relatively new and had no water when I drained it), reassembled the hoses, clamped everything tightly and started pumping. When the pump got heavy, I bled the system on all 4 injectors including the feeder's bleed screw. After 5 seconds on the glow plug, cranked and it started off with one click. Idled the engine for around 15 minutes then turned the engine off.
    Tried starting later after the sun went down (approximately 7 hours from the last start) and it's still a one-click wonder. Will be observing in the later days if the problem is finally addressed. The joys of being able to fix stuff by one's self is priceless (aside from the pesoses saved on labor costs)
    Thanks and more power Dieseldude!
    #1732
    Quote Originally Posted by kramterrag View Post
    Hi Dieseldude,
    Need some advice on how to solve jerking problems on my pick up. Kapag nasa 3rd & 5th gear siya and accelerating and at 1100-1200 rpm ko na-e-experience yung jerking. Is this normal? or something is wrong with my pick-up?
    Thanks in advance.
    Sir will try to butt in, Does this happen regularly or just sometimes? if sometimes its common for Isuzu engines if the accelerator pedal is pressed hard suddenly at this rpm range, try to gradually press the accelerator pedal or change to lower gear to increase speed.
    BTW sir dieseldude, 4JB1t Isuzu TFS55, How do I know if thepriming pump is broken already? Have air in the system and can't find the leak pa, the priming pump is only about 2 years old original isuzu.
    Sep 2006
    #1733
    Got it! I noted all your recommendations Thanks a lot dude. You d' man!
    Sir Deiseldude,
    I acquired a 1998 Adventure GLS M/T Dsl. Its in running condition, not really worn looking. Aircon is ok, instrument panel is also working. 110k sa odometer, hindi naman na-ondoy.
    Its my first time to handle a diesel car/engine.
    I dont hav a background as to its maintenance or repair history so i plan to have it checked. Parang general checkup. so my question is this:
    What are the parts/components that need
    1) replacing outright: Replace timing belts and tensioners
    2) adjustment or repair: Check/replace brake pads/shoes, check handbrake adjustment, check tire wear.....wheel alignment if necessary
    3) checking: Check for cracked/weak coolant hoses, intake air hoses, and fan belts, check coolant additive
    Like for example, sabi ng driver namin, change oil na agad along with filters since we dont know when was the last change oil. Correct, replace fuel and air filters.
    Palitan ko ba lahat ng mga belts? Better.
    Any particular belt na dapat pinaka importante mapalitan? Timing belts and tensioners.
    Fuel pumps? No
    Compression test ba? No
    Is calibration in order na? Kelangan ba ipacheck ang fuel injection (i just read this from another thread). No if it's running well and doesn't smoke..
    Meron bang common electrical issue ang adventure na dapat unahan ko na at maipagawa? Depends on what you see..
    May nakabudget ako na money for engine rehab na around 20-30k kung talagang kailangan. Okay na yan...
    THanks dude! You're welcome
    Sep 2006
    #1734
    I'm glad you posted your experience. This will encourage fellow DIY Tsikoters.
    Sep 2006
    #1735
    BTW sir dieseldude, 4JB1t Isuzu TFS55, How do I know if the priming pump is broken already? It won't pump fuel.
    Have air in the system and can't find the leak pa, the priming pump is only about 2 years old original isuzu. Check for loose hose clamps or sealing washers. Check for bad oring seal on top surface of filter, worn seal on bleeder screw, bad threads/seal on water sensor and drain plug.
    May 2012
    #1736
    hi sir DieselDude,
    I have a pajero 4d56 TDIC, hard starting everytime the engine is cold and biglang mamatay engine, kailangan kong i-rev ung engine above 1500 for 1 minute para di mamatay, mausok, losing power when going uphill, mabagal ang arangkada pag naka-on ang a/c, may mga times pa na bigla na lang mamatay ang engine pag naka-stop then kailangan nang umbante kaya pinapatay ko a/c kapag nakastop ako para hindi mamatay pag abante, what could be the problem?
    thanks
    Aug 2010
    #1737
    i tried driving my friend's L300. i noticed that it won't go beyond 70kph. i asked my friend about it, and he told me that its been like that for years even after change oil, filter etc. what do you think is the problem? is it fuel injection pump?
    Sep 2009
    #1738
    Sir,
    I just bought a 2002 nissan patrol diesel and its casa maintained. So far i dont have any problems w the car except that i heard that di daw pwede basta basta diesel engine oil dun, maselan daw parang isuzu trooper na pag ibang engine oil ginamit mo magloloko as per the service advisor of nissan.Is this true? Is there no other way every change oil na ipa change oil sa labas since its already 10 years old even if use synthetic motor oil? Your reply/ comment would highly be appreciated.We had an isuzu trooper before but it was sold as even if we were buying BESCO oil from isuzu mausok parin.
    Sep 2006
    #1739
    Quote Originally Posted by vincr View Post
    hi sir DieselDude,
    thanks
    Malaki ang posibilidad na meron problem ang injection pump.....
    Sep 2006
    #1740
    Quote Originally Posted by trucker111 View Post
    Check accelerator pedal and cable adjustment. Injection pump control lever should be against maximum speed screw on injection pump when pedal is floored. If not, adjust cable....
Diesel Fuel Injection System Help Desk
