sir takumi san/diesel dude,
share ko lang po experience me abt pajero hardstarting
my ride is a 95 model pajero, local version with 4d56 tdic
hard start dn po..and after starting, may black smoke spurting at first, then light smoke followed while engine is still cold.
first action taken, replaced air filter...replaced all the glow plugs with good one...also found out that the glow plugs relay are not working..also replaced with original glow plug relay at php2300, and php300/each for glow plugs...medyo nabawasan ang redondo nya bago mag start5..dati mga 15 redondo bago mag start...after replacing relay and glow plugs, naging 10 redondo nalang...
2nd action taken, replaced fuel filter and fuel filter body with replacement brand only...bad move...not original fuel filter body have generally poor check valve mechanism/material w/c causes the back flow of diesel, thus contributing to hard starting.. no choice but sorted to original fuel filter body for php 3500, and original fuel filter element for php 1400 from mitsubishi motors... after replacing fuel filter and body, from 10 redondo naging5 redondo nalang...
3rd action taken, had my injectors and injection pump calibrated...and replaced worn out parts including all 4 nozzle tips, and some injection pump parts...caused me php 13800 for labor and materials... guess what, hard starting is completely solved...from 5 rodondo, now, it only take 1 redondo (crank) and the engine starts easily...with 1 heating cycle only and at cold weather...and i was happy because the noticeable tail pipe smoke is now a thing of the past...may konteng spurt of light smoke lang pag start ng engine and after that, wala nang makikitang usok, as in.. sinubukan ko nga ring itutok ilong ko few inches from tail pipe, d sya masakit sa ilong kumpara dati...
and mas naging responsive at maganda power ng engine at mas tumaas fuel mileage ko after those steps...
kaya i don't believe na sabi ng iba, sakit daw ng pajero ang hardstarting at black smoke...proper engine maintenance lang po...
hope sharing my experience helps...
thanks mga sirs.
