Results 1 to 10 of 77
May 4th, 2005 11:32 PM #1
How much more fuel-efficient are EFI engines? In percentage, ball park figures.
Let's take for example the Corolla XL with 1.3 engine, versus the Vios with 1.3 engine.
May 4th, 2005 11:50 PM #2
Originally Posted by Psylocke
A carb engine can either be tuned for power or efficiency but hard to do both well, it will always be a compromise if you want both.
Comfort, heck, a new car is still much better.
- Jan 1970
- 81
May 5th, 2005 12:13 AM #3IMHO, there are so many variables kaya mahirap mag generalize. Yung XE and Vios are generations apart as far as engine design is concerned so apples to oranges nga.
I think if you have lead foot syndrome, mas magastos ang EFI than carb. I'm guessing the fuel pump of EFI's are more powerful and the injectors effectively fuel discharge will be higher than a carb design.
Of course you can change injectors and jets/carbs but in general, yun ang hula ko.
May 5th, 2005 12:24 AM #4
Generally, EFI engines are more efficient than carb ones with the same displacement. The Vios 1.3 EFI with VVTi has been tested to be significantly more efficient than the 2E 1.3 engine of past Corolla XLs and XEs. It is believed that new technology progressively translates to engines with more performance but same efficiency, same performance but better efficiency, or even both.
SiRaNeko
- Jan 2003
- 973
May 5th, 2005 05:01 PM #5so better to get the vios, if fuel efficiency ang concern rather than the xl/xe.
halos pareho ang presyo nila na brand new
- Sep 2004
- 175
May 5th, 2005 08:07 PM #6more performance but same efficiency, same performance but better efficiency, or even both.
December 7th, 2005 09:32 AM #7
tanong ko lang kung ano yung mas fuel-efficient and less maintenance, carb-type engines o fuel-injected?
thanx!
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
